Thank you very much to VANOS for posting the dump and TANGO who helped me with precious informations. I managed to make my carprog work really good,Next i will make the antenna.
vanos batam (30th January, 2017)
this fw 8.21 works with FIAT GRANDE PUNTO? i see only app saying UPDATING then CONNECT ERROR
Don t konw did not test fiat. Try to rework A1 adapter.
i make the interface how come with h-jtag manual and its works perfectly.the one with lpt never i could flash with it i dont now why,it had the some h-jtag configuration.thanks to everybody.
Carprog is working good
Hi there,
i am kinda new to this. But i keep reading about the recommendations to upgrade the hardware on china clone units.
Like the crystal and capacitors and such. Am I understanding this right? Those changes would make the actual
function of the unit more reliable? Or is this a prerequisite for flashing the mcu?
As to flashing the mcu: I would need the firmware and the .lib file which must match, as well as some sort of
jtag-hardware plus the a programming software i.e. Ponyprg that can handle the mcu type. And the existing
At88 should not even be tried to be read, because that would already change its content. Did I get this about right?
Is there more to know which I didn't catch?
you got it right yes
do not in any way or reason try to read at88c (there is no reason to touch this ic)
leave it well alone dont even remove it
pcb modifications/rework is to help make the carprog more stable.
ADEL.KSHLAF (24th January, 2018)
what firmware ver. was in VANOS's post 497?
can somebody share it again
I have saw your post but want to check that file is it real or just changed serial number .I have saw many bin files which is actually fake and fake lib file too. I think posted files which is just renamed (lib files ) and changed serial in the bin files can't work properly even offline
theres a few versions around now that are fw 8 with changed serials only
they are all the same dump but with serials changed as said
Plz need advice to buy china clone carprog... which china clone,,? pcb,version,seller ?
you could buy any version because when you do they all need rework
ie caps wrong way round or missing completly etc
and most out there are only fw4
if you want latest version with less work needed then go for the 8.21 version only
this will save you having to reflash it but you will still have to check and see if everything on the pcb is correct
all other version for sale is really with fw4 (so if you see v9.31 etc it will really have only fw4 and lib for version 4.01 sw)
mrchip (2nd April, 2017)
