Page 42 of 51 FirstFirst ... 323738394041424344454647 ... LastLast
Results 616 to 630 of 752
  1. #616
    otojm's Avatar
    Feb 2012
    Kepler 22b
    Quote Originally Posted by brchip View Post
    I'm trying to reflash mine. I read and follow all instructions here but I get that message TARGET NOT FOUND from JTAG.
    Maybe it's not erased completely? To erase I first connected pin 55 to ERASE point but that didn't seem to work. Then I connected to +3.3V as I read soemwhere here and now windows is not recognizing it anymore, so it should be cleared?
    There seems to be more than one way to erase the MCU:
    -connect to ERASE point
    -connect to ground
    -connect to VCC
    -connect to +3.3V
    Which one is right?
    Should I keep pin 55 connect to ERASE point during JTAG operation or not?
    I would aprecciate the HELP!
    Thanks in advance.
    Attachment 487087
    Attachment 487088
    i do like this without any problem:
    Erase mcu:Connect the Carprog (with the pin 55 disconnected) to the 12v supply, wait about 5-10 seconds and connect the wire from pin 55 to VDD in Carprog,
    the flash content will be erased and the Jtag option of the Mcu will be enabled now. If not work leave connected for about 3 to 5 minutes.
    1-GND(for normal connection)
    2- to Erase-point VDD (for erase the MPU)
    3- Lift it without any connection with the PCB (for programming) .
    regards
  2. The Following User Says Thank You to otojm For This Useful Post:
    brchip (20th November, 2017)
  3. #617
    Quote Originally Posted by otojm View Post
    regards
    Thank you m8.
    I found the problem: the JTAG settings.
    I was using this one, and it didn't work:
    When I used this settings it worked:
  4. #618
    I reflashed my Carprog 7.28 with LIB 081105CAR001773I (is it actually 4.01?) and it seems to be working fine, no counter anymore.
    My question is, can I reflash it with a different version, like the ONLINE 8.21 and LIB 150428CAR00491KW?
    I guess not?
  5. #619
    Sep 2016
    south africa
    Does someone have a pinout to read 93c eeprom for carprog pls. I don't have a decent or standard cable.
    Tnx
    Sent from my EVA-L19 using Tapatalk
  6. #620
    Aug 2016
    Quote Originally Posted by mister opel View Post
    Tnx
    Hi look here
    http://www.codecard.eu/carprog/softw...0/prod_48.html
    http://codecard.eu/carprog/adapters/...r/prod_55.html
  7. #621
    Aug 2012
    EU
    hi
    needed hjtag software.
    sorry for me bad english.
  8. #622
    Jan 2017
    Does any one fancy doing this to my carprog? Im willing to pay
    Gav
  9. #623
    Aug 2012
    EU
    Quote Originally Posted by elremont View Post
    hi
    please add in rar archive
  10. #624
    Aug 2014
    Cool This connection
    Hi thank you for this solution, ill try it in a couple days . Just one question, why this connection ? Thanks
    Edit : I mean the top "bridges gnd"
  11. #625
    Jun 2011
    Northamptonshire, UK
    Quote Originally Posted by monstermurga View Post
    To ensure a good ground connection to the voltage regulators..
    Sent from my iPhone using Tapatalk Pro
  12. The Following 2 Users Say Thank You to Music73 For This Useful Post:
    A630V (14th September, 2018), monstermurga (16th January, 2018)
  13. #626
    Oct 2015
    Hi, I have carprog 8.21 and I have some problems writing by Kline (I don't try another kind of writing). I tried to writing ABS bmw E46 by Kline in bench and Dash MB Vito MC68. My carprog can read fine, but can not write! Write without errors but read again and no change!
    What can I do to solve problem?
  14. #627
    otojm's Avatar
    Feb 2012
    Kepler 22b
    Quote Originally Posted by Perryking View Post
    hi,it happened for me with renault dash with nec, and i close/disconnect from power the dash and repeat the work again to have good write!
    so perhapes this can be usefull for you to test...
    PS:it looks like there's a service-shedull that must be done in first attempt then it do the right correction in second attempt !!!
    regards
  15. #628
    Jan 2016
    Quote Originally Posted by adekbws View Post
    Hi My carprog was good, i wanted to flash firmware to 8.21, but my jlink can't connect to mcu "ERROR: Could not find supported CPU core on JTAG chain" , i made one mistake , solder pin 55 to erase connect that : http://www.mediafire.com/convkey/67a...4qon77yozg.jpg and connected other pin do jlink and try program , so whether it caused a microcontroller damage ?
    I have same Error, cant connect to carprog..I tried all connections that I can find on forum,,in the end pin 55 is broken, paid new mcu but i get same error message..
    I use china clone segger jlink ,, can someone share jlink program which one did work for you ? maybe software is not good, my program is v4.26
  16. #629
    Quote Originally Posted by mrchip View Post
    Did you try this?
    I found the problem with mine: the JTAG settings.
  17. The Following User Says Thank You to brchip For This Useful Post:
  18. #630
    Jan 2016
    Thanks mate, I use segger Jlink,, I dont have your software
