Need some help i did the upgrade but now my computer doesnt recognize thr carprog
Did u solve the usb device not recognized code 43 issue?
Do someone have MYKO201607010014.lib file for CarProg?
Thanks!
Hello, my friends, I have had this problem with Carprog, I update the MCU with V8.21 and I use 150428CAR00542UA.Lib, Carprog works very well with few N / A, but it only works for about 15 minutes, then it's as if had lost the MCU's programming, no longer being recognized by the USB port.
I make a new recording on the MCU back to work, but for only 15 minutes + or - , getting only ????????????? in place of the numbering of the lib in the lower left corner of the program.
I changed the mcu for a new one, but it's still a problem.
If I was useful to you, thank you by pressing the thank you button .
i need this dump .(link not work) AT91SAM7S256 bin
AT91SAM7S256 bin for you
ADEL.KSHLAF (28th January, 2020), adrianoo (2nd May, 2018), girolamodisidisi (5th January, 2022), lnasteski (12th June, 2020), magav25 (15th August, 2018), MRAWZIN (31st July, 2019), Phoeny (21st May, 2018), pollito128 (9th May, 2021), sep382 (3rd May, 2021), urbajs (23rd October, 2018)
hello please tell can carprog read this type of mcu clio 4 dash 9S12XHY 256
I tried to lift reset pin but instead the trace of pin 55 lift up ,does it goes also under the mcu or just in the visible area ?
I get this error !! any idea why ??
hello colleagues, if you have one of you a 8.21 verz on exe. for carprog clone, to put it here
yes, for now it works with ONLINE 8.21 and LIB 150428CAR00491KW
I have to try with more cars to make sure everything is ok
znajdowany wsad do carprog wersji v8. 21
https://www.360diag.net/a/downloads/.../1109/397.html
tylko nie mam kodu aktywacji.
może ma jej kalkulator do pomocy?
jeżeli ma ktoś kalkulator lub może policzyć ?
bardzo bym prosił o pomoc
68766-D08B5-BE006-A91EB
andreata (22nd January, 2021), mihnea1986 (19th October, 2018)
I flashed the Firmware 150428CAR00491KW.bin to my CarProg.
CarProg V8.21 online.
I got Problem to connect to CAN Bus with follow 2 Functions:
Dashboard-VW-Scirocco2009-OnlineDiagv0.2
Dashboard-VW-Scirocco2012-OnlineDiagv0.2
Both wont connect with A1Cable.
