please upload mcu firmware without at88 workng. i test with cp 4.01 without AT88.bin and work. Reason burnt at88
For sirocco need a1+ adapter
Wysłane z mojego SM-G920F przy użyciu Tapatalka
Can me anyone say how the steps to Dump a Carprog Flash File?
is encrypted
Keep in mind, English is not my native language.
hello, is it safe to flash the carprog without removing the at88sc? without harm?
should the wire 55 be resized on the pcb after reprogramming?
Small circumstances produce great events : 02.47-tranquillité:
gege974 (23rd October, 2018)
According to the datasheet, pin 55 can be left unconnected.
ERASE Pin
The pin ERASE is used to re-initialize the Flash content and some of its NVM bits. It integrates
a permanent pull-down resistor of about 15 kΩ to GND, so that it can be left unconnected for
normal operations.
thank you for the information
hi
topic: JTAG programming for Clone Carprog
I have bought CarProg and TL866ii PLus programmer with 10 Adaptors
TL866 Link : https://www.ebay.co.uk/itm/USB-TL866...72.m2749.l2649
and Carprog
https://www.ebay.co.uk/itm/New-VSCAN...72.m2749.l2648
I have searched on JTAG programmer and adaptors but It is very confusing as there are different ones depend on the MCU manufacturer.
I do not have a serial port on my laptop. it is windows 10 with USB ports. Which cable do i need to buy.
Please send a link for item in sale.
Many Thanks!
If you want to reflash CarProg you can use J-Link
Mustansar (9th November, 2018)
Hi everyone! After reflashed carprog, I reconnect usb, but nothing happens..PC not found device. When erasing mcu pc found uknown device. Possible couse?
