Page 35 of 51 FirstFirst ... 25303132333435363738394045 ... LastLast
Results 511 to 525 of 752
  1. #511
    Aug 2008
    Quote Originally Posted by flamurf View Post
    frinds,i need chmatic to build a Hjtag from LPT port,please help
    you mean this 1 ?
  2. The Following User Says Thank You to tango For This Useful Post:
    leotdx (24th January, 2017)
  3. #512
    yes thanks
  4. #513
    i will try and report
  5. #514
    i need your hep friends,i can?t acces the procesor
  6. #515
    Jan 2012
    Try change to LPT instead of USB.
  7. #516
    so i have done it,i upgrade my carprog clone to 5.31 , can i upgrade it higher to carprog 8...
  8. #517
    Yes find on this forum atmega flash v8 and writhe to atmega
  9. #518
    pike's Avatar
    Sep 2013
    Who has soft V9.31 for clone?
  10. #519
    friend any idea about higher software uppgrade
  11. #520
    Aug 2008
    Quote Originally Posted by pike View Post
    why do you need it there is no higher firmware than fw version 8
  12. #521
    pike's Avatar
    Sep 2013
    I need a few features of this software.
  13. #522
    Jan 2013
    Inside ECU
    Tried that v8 flash and does not work. I updated mcu , found serial and when i tried to test interface disconected and then device damage. I reflashed with other bin and know it works. Any one else flashed that dump?
  14. #523
    Aug 2008
    Quote Originally Posted by leotdx View Post
    which dump ?
    version 8 dumps thats now posted over the internet are all working
    if you had a problem with it then try to erase the mcu again and reflash, something must have gone wrong.
  15. The Following User Says Thank You to tango For This Useful Post:
  16. #524
    Jan 2013
    Inside ECU
    From post #497 and doesn t work
  17. #525
    Dec 2012
    hello i have the some problem with lpt jtag like flamurf with the some pictures in post 514,can somebody help me please.thanks
