Maybe this help
ok thank you friends....
I will try to buy new mcu atmel
Excuse me, anyone can help me? Soft carprog see a hardware car prog drive usb install well, but soft carprog not recognize a serial nunber. Any idea or help me? Tanks in advance.
Multipla (3rd December, 2018)
Hi Mates
I want to replace at91sam256 on my carprog, because it is broken, I soldered an NEW at91sam256 ( B ) but cant flashing by Jlink,
j link does not detect carprog , also laptop does not detect it with new at91sam256,
it is because of new at91sam256 is blank ??? or by another reason ?
No no the tool was fine, then I updated firmware with J-link and carprog no longer worked. I just remember to have put OBD + carprog banana and have done obd and tool tests and it did not work +. That this.
[QUOTE=mikroel;3437557]Explain what you did before this problem .
It seems bad fw or bad processor
No no the tool was fine, then I updated firmware with J-link and carprog no longer worked. I just remember to have put OBD + carprog banana and have done obd and tool tests and it did not work +. That this. J- link fetected the chip I suppose eeprom At88 sc work but drive usb work but the software not detect serial nunber of tool. It only problem. I dont know.
now I get this error " tck(pin9) low, but should be high, please check target hardware"
TCK is not short to ground
before error " Suply voltoage too low, ( 1 volt is required , measured 0.9 volt ) ,, multimeter show 1,14 and 1,10 volt on pins of carprog)
someone has same error ?
Hello!
I bought J link version 9.5 and software version 6.40 . I downloaded the software from Segger web . Connected to the Internet and update firmware to the latest version itself . I have difficulty with the project settings . For older versions of the software, there is how to set up the program. I do not find info for this version. In the MCU section of the tagged zone I have data . Do I write these data or bring itself ? Currently J link and Carprog are not connected and this section is empty to me. The other thing that bothers me is Target Power Supply .A things okay?
Thank you!
