Page 5 of 51 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 752
  1. #61
    Jan 2011
    Default CARPROG A1 RESISTOR
    PLEASE HELP HOW TO RESISTOR
  2. #62
    polska
    resistor 1002
  3. #63
    Jan 2011
    pozdrawiam
  4. #64
    kowalwalcz's Avatar
    where to buy carprog clone ? Trust seller and full working soft ??
    if I helped You, press the button THANKS
  5. #65
    Jan 2011
  6. #66
    Oct 2012
    Vitebsk
    work carprog A1
  7. #67
    Aug 2012
    Polska
    Quote
    My problem is the following:
    4:01 Cone writes: Device locked. Connect Update Server to synchronize
    It is possible to fix this?
  8. #68
    ALEXEI's Avatar
    Quote Originally Posted by Pakli30 View Post
    Quote
    if you connect it on server you will lock it forever
    only reflash mcu can solve the problem
  9. The Following User Says Thank You to ALEXEI For This Useful Post:
    shadab (14th November, 2016)
  10. #69
    Quote
    Check:
    http://www.digital-kaos.co.uk/forums...p-step-288814/
  11. #70
    Default dump for eeprom at89cs
    please upload dump for eprom at89CS and thanks
  12. #71
    hi
    Any one help me with discribe pins on my jtag it is very old usued before to programming sat tuners
  13. #72
    Nothern California
    Can carprog clone be used as a serial eeprom to read and write serial eeprom like 93x or 24xxx that be a good things or still need a programmer ?
    also only work ews3 ?
    Knowledge is the Key
  14. #73
    Nov 2011
    Quote Originally Posted by hauwkee View Post
    Yes, carprog clone can be used as serial eeprom programmer
  15. #74
    Aug 2012
    Polska
  16. #75
    Jun 2012
    Default h-jtag error can't load h-jtag.dll
    Hello!
    h-jtag flash say: error: can't load h-jtag.dll
    on windows 98 LPT1 port
    Plase help!
    I try write AT91SAM7S256
