Page 1 of 51 12345611 ... LastLast
Results 1 to 15 of 752
    audiotek's Avatar
    May 2011
    Default Carprog Mcu Reflash Step by step
    Here is how to reflash CARPROG Mcu AT91SAM7S256 step by step, first of all I wish to thanks to lupu_sandu, elchip, autocargo, Tachonow, carradio2001 and all DK forum members who made this possible.
    I bought my Carprog clone 4.01 from digi_obd but after about 50 uses starts a counter: "260 uses left - update hardware to synchronize" and was decreasing, anyway 260 uses is big number to recover the investment (us $209 dlls), the programmer was paid before the counter starts.
    Ok, first we need this stuff:
    1.- AT91SAM7S256 bin:
    http://www.digital-kaos.co.uk/forums...og-rev-0.3.rar
    2.- Jtag programmer:
    3.- Jtag software:
    http://www.digital-kaos.co.uk/forums....1-release.rar
    We need to prepare the Carprog to connect to Jtag programmer but first the flash need to be erased, the Jtag function in mcu is dissabled, you can't connect to the mcu before erase the flash. Remove the AT88SC eeprom from the board, please note where is the pin 1 in eeprom before remove:
    Carefully lift the pin 55 (reset) of the mcu and solder a wire and secure it with a small ammount of silicone (you don't want to broke the pin in the process).
    Connect the Carprog (with the pin 55 dissconected) to the 12v supply, wait about 10 seconds and connect the wire from pin 55 to Vcc (3.3V) in Carprog:
    Wait from 5 to 10 seconds after connect the 12v supply, the flash content will be erased and the Jtag option of the Mcu will be enabled now. If not work leave connected for about 3 to 5 minutes. Disconnect the 12v supply from carprog and remove the pin 55 wire from vcc. The pin 55 must remain disconnected until the programming process is done.
    Install the H-JTAG software in your pc.
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Willem PCB50, Masterprog, NecProg, Orion, Ponyprog, Carprog, Renesas H8SX, MT60/80, SPC560 programmers,Obdstar X300DP, EZ500, CHIPSOFT MID,SKP1000,Cantool, SuperVag 3.0, Vag Commander, Vagcom Original, Launch x431 Pad, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Mastertech VCI, EASE j2534, Ford & Mazda VCX, TS401, Cardaq-m, DIS 5.7, VAS5054 Plus, Tachopro 2.0 & 2008.01, Vag K+Can, JLR v141.....
  2. The Following 55 Users Say Thank You to audiotek For This Useful Post:
    Adamdad (8th September, 2021), ADEL.KSHLAF (27th January, 2018), Alfik (14th March, 2016), ali kaptan (27th October, 2022), angelx431 (23rd April, 2017), bravel digital (4th June, 2014), cheaper (4th March, 2014), Chokito5 (27th August, 2013), ciurkiempisane (4th May, 2015), Col19 (6th June, 2021), cole_mcs (6th July, 2013), cosmin12345 (24th August, 2014), csavargo2 (8th December, 2014), cuiuda (24th April, 2013), Danimp94 (16th March, 2019), deondti (2nd July, 2014), Dodgyknees (11th May, 2019), doud77 (5th December, 2016), fanos (17th September, 2013), Faraday (3rd October, 2014), gabi2014 (1st June, 2014), genius76 (9th October, 2013), Ginocar (13th October, 2013), hoangtu (17th April, 2016), jarripote (25th December, 2013), Jchip (7th November, 2018), jebson (12th August, 2014), jomberykaso (11th November, 2013), kalico (5th November, 2014), kukasIII (1st June, 2017), kuzmichh (4th May, 2013), leandroks (13th May, 2013), ligno1 (7th April, 2013), melectro (26th September, 2013), mihnea1986 (19th October, 2018), mohamedkey (18th August, 2013), monstermurga (16th January, 2018), narkeleptk (22nd May, 2017), nath15 (8th June, 2021), NELGLIDER (20th June, 2014), ozuque (6th December, 2016), pandokrator (6th November, 2013), ph0en1x (1st October, 2013), rm23 (29th September, 2013), rosak (31st August, 2017), sergei5005 (4th November, 2015), shadab (14th November, 2016), stromin (3rd April, 2018), Talleresmalaga (28th November, 2017), teamone (11th September, 2013), tk74 (19th September, 2013), traxpalicaru (15th May, 2019), tsanev (7th July, 2022), valty (28th April, 2016), yvespapou (23rd January, 2014)
  3. #2
    audiotek's Avatar
    May 2011
    Now we can make the connections from Carprog to Jtag programmer:
    Carprog Pinout:
    Jtag Pinout:
    And here is the Carprog connected to the JTAG programmer (note that the pin 55 wire is disconnected):
  4. The Following 31 Users Say Thank You to audiotek For This Useful Post:
    Adamdad (8th September, 2021), Alfik (14th March, 2016), ali kaptan (27th October, 2022), barteczekk (22nd January, 2014), bravel digital (4th June, 2014), Chokito5 (27th August, 2013), Col19 (6th June, 2021), csavargo2 (8th December, 2014), davidjona (29th October, 2019), deadliner (20th July, 2013), doud77 (5th December, 2016), Faraday (3rd October, 2014), gabi2014 (1st June, 2014), genius76 (9th October, 2013), Ginocar (13th October, 2013), hoangtu (17th April, 2016), jarripote (25th December, 2013), kuzmichh (4th May, 2013), leandroks (13th May, 2013), Mac Gyver (19th October, 2013), mancinofranco (18th October, 2013), mohamedkey (18th August, 2013), Mustansar (31st October, 2018), rm23 (29th September, 2013), rosak (31st August, 2017), sergei5005 (4th November, 2015), shadab (14th November, 2016), traxpalicaru (15th May, 2019), tsanev (7th July, 2022), valty (28th April, 2016)
  5. #3
    audiotek's Avatar
    May 2011
    After the H-Jtag sotware is installed we can procced to configure:
    Open the H-Jtag server and make the adjustments:
    Select the port:
    LPT Jtag setting:
    TAP configuration:
    Target manager:
    Now connect the carprog to JTag programmer and 12v supply and press "Detect Target" in H-TAG server, now the Carprog Mcu is detected!!!:
  6. The Following 25 Users Say Thank You to audiotek For This Useful Post:
    Adamdad (8th September, 2021), Alfik (14th March, 2016), Autronic (1st March, 2014), bravel digital (4th June, 2014), Chokito5 (27th August, 2013), Col19 (6th June, 2021), csavargo2 (8th December, 2014), cuiuda (24th April, 2013), doud77 (5th December, 2016), doudou241 (8th October, 2013), gabi2014 (1st June, 2014), genius76 (9th October, 2013), Ginocar (13th October, 2013), hoangtu (17th April, 2016), jarripote (25th December, 2013), kuzmichh (4th May, 2013), leandroks (13th May, 2013), Mac Gyver (19th October, 2013), mexanico1971 (8th October, 2016), mohamedkey (18th August, 2013), rosak (31st August, 2017), shadab (14th November, 2016), tareqqasem (6th October, 2016), traxpalicaru (15th May, 2019), tsanev (7th July, 2022)
  7. #4
    audiotek's Avatar
    May 2011
    Now we procced to program the AT91 mcu:
    Start the H-FLASHER and select the AT91SAM7S256 from the list:
    -Go to "4 Programming" in the programming wizzard and press "Check" to verify the communication with the target mcu, if all is ok the values must be:
    Flash: AT91SAM7S256 0x270D0940
    Target: ARM7TDMI LITTLE-ENDIAN
    -In "Type" select: "Plain Binary Format"
    -In "Dst Addr" select: "Flash Base Address"
    -In "Src File" select the location of the AT91SAM7S256 bin in your hard drive.:
    Now press the "Program" button and wait to finish:
    If the progrmming was succefull you will receive the next message:
    You can verify again if everything is ok by pressing the button "Verify":
    The programming process is finished!!, disconnect the 12v supply, then disconnect the programmer from carprog, solder the pin 55 wire to Ground (check the picture) and put back the AT88SC eeprom, reassemble the carprog and test it.
    I already made some further tests and the Carprog works well with any version of the software and the COUNTER IS GONE!!!
    Tested with versions: 3.75, 4.0, 4.1, 4.5, 4.85 and 4.86, the counter never start again.
  8. The Following 30 Users Say Thank You to audiotek For This Useful Post:
    Adamdad (8th September, 2021), ADEL.KSHLAF (28th January, 2020), Alfik (14th March, 2016), angelx431 (11th December, 2015), autocar88 (2nd January, 2017), bangreno (11th December, 2014), borysgo2 (4th July, 2014), Chokito5 (27th August, 2013), Col19 (6th June, 2021), csavargo2 (8th December, 2014), doudou241 (8th October, 2013), genius76 (9th October, 2013), giani03 (6th June, 2013), Ginocar (13th October, 2013), hoangtu (17th April, 2016), Jardel (24th April, 2021), jarripote (25th December, 2013), konop11138 (2nd February, 2015), kuzmichh (4th May, 2013), leandroks (13th May, 2013), line44 (7th January, 2017), mohamedkey (18th August, 2013), Msmax (2nd March, 2020), PETERALC506 (15th October, 2013), Saman (14th April, 2014), seal777 (20th June, 2018), shadab (14th November, 2016), tinerfe30 (15th August, 2013), traxpalicaru (15th May, 2019), tsanev (7th July, 2022)
  9. #5
    audiotek's Avatar
    May 2011
    Default Carprog modification for fast reflash
    I made a modification to my Carprog clone for fast reprogramming, if I need to do it again will not be necessary to open it again and redo all connection every time I want or need to reprogram:
    I used the Carprog pins from 15 to 21, those pins are useless for the programmer or any adapter, they are disconnected:
    I used a "selector" like the desktop's pc for bios, to select the programming mode, in picture from left to right: 1, 2 3, if the jumper is placed at pins 1 and 2, the pin 55 (reset) from the AT91 is shorted to ground, preventing deprogramming or programming the MCU, if the jumper is placed at pins 2 and 3 the pin 55 is shorted to vcc 3.3v and the Mcu is placed in ERASE MODE. Without jumper the mcu is placed in programming mode:
    Now is probably a waste of time, in the near future will save me some time but from now I can reflash the AT91 in less than 5 minutes.
    Update: I forgot to mention that I doesn't need to remove the AT88SC eeprom to ERASE/REFLASH the AT91 mcu. After that the Carprog works well. This is MY OWN experience, so, If you want to do the same, do it at YOUR OWN risk.
  10. The Following 25 Users Say Thank You to audiotek For This Useful Post:
    Adamdad (8th September, 2021), arti1 (24th September, 2015), buzz84 (1st January, 2014), Chokito5 (27th August, 2013), Col19 (6th June, 2021), csavargo2 (8th December, 2014), DieselManiac (27th February, 2017), Dobermann (13th January, 2021), doud77 (5th December, 2016), doudou241 (8th October, 2013), Ginocar (13th October, 2013), jarripote (25th December, 2013), just4upal (15th March, 2016), mancinofranco (14th March, 2014), medcapot (10th June, 2013), mexanico1971 (8th October, 2016), mohamedkey (18th August, 2013), PETERALC506 (15th October, 2013), seal777 (20th June, 2018), shanektm450 (9th March, 2014), sky0802 (27th August, 2017), traxpalicaru (15th May, 2019), tsanev (7th July, 2022), ubela (14th October, 2017), urcarpc (20th April, 2013)
  11. #6
    Apr 2010
    LT & ES
    And how you plan to remove fast AT88SC eeprom, to protect it's content?
  12. #7
    ahadi's Avatar
    Sep 2009
    I have question about the ground
    why this connection .
  13. The Following 2 Users Say Thank You to ahadi For This Useful Post:
  14. #8
    carradio2001's Avatar
    Nov 2009
    France
    Quote Originally Posted by audiotek View Post
    Not necessary IF use the correct dump !
    Carradio2001.
  15. #9
    audiotek's Avatar
    May 2011
    Quote Originally Posted by olegario View Post
    Here is your answer:
    I have two Carprog clone units, so, I take the risk and make all the reflash procedure without removing the AT88SC eeprom and the results are the same: the carprog unit works well after reflashing, the contents in AT88SC eeproms remains intact. I already make some tests with airbag modules, eerpom reading, some dashboards and mcu's and everything is ok.
  16. The Following 11 Users Say Thank You to audiotek For This Useful Post:
    Adamdad (8th September, 2021), ADEL.KSHLAF (27th January, 2018), Chokito5 (27th August, 2013), Col19 (6th June, 2021), Dobermann (13th January, 2021), doud77 (5th December, 2016), line44 (7th January, 2017), rtbdiagnostic (10th March, 2020), satalightmad (24th June, 2017), shadab (14th November, 2016), tsanev (7th July, 2022)
  17. #10
    audiotek's Avatar
    May 2011
    Quote Originally Posted by carradio2001 View Post
    Carradio2001.
    As I said at the end of the post: "Now is probably a waste of time, in the near future will save me some time but from now I can reflash the AT91 in less than 5 minutes." I doesn't share this with the intention that other people do the same, it's your/they choice and risk anyway, it's only to comment that it's possible reflash the carprog MCU without removing the AT88SC eeprom (at my own experience). BR...
  18. The Following 5 Users Say Thank You to audiotek For This Useful Post:
    Col19 (6th June, 2021), isma123 (7th April, 2017), mexanico1971 (8th October, 2016), traxpalicaru (15th May, 2019), tsanev (7th July, 2022)
  19. #11
    Nov 2009
    France
    That's good to know, re-flash possible without removing AT88SC eeprom.
    Carradio2001.
  20. #12
    Feb 2010
    Default Carprog Software
    Does this mean that the carprog software will have all the functions of software version 4.86?
    If so does anyone know where I can get the software from please?
  21. #13
    radsky's Avatar
    May 2012
    Earth
    Quote Originally Posted by coops43 View Post
    no
    use magic "search" button.
  22. #14
    Feb 2010
    Quote Originally Posted by radsky View Post
    no
    I can't find it!!!!
  23. #15
    Jul 2011
    Is this jtag ok for the job?
    It's an old one i have here from sat boxes.
  24. The Following 12 Users Say Thank You to guilhermegti For This Useful Post:
    ADEL.KSHLAF (28th January, 2020), Barry1 (26th January, 2022), Col19 (6th June, 2021), fako22 (11th December, 2018), houdiag (16th September, 2016), juanes 3 (8th October, 2016), nassim02 (6th April, 2017), pintobraz (6th August, 2014), RevBernie (9th April, 2021), tomxx (18th November, 2021), traxpalicaru (15th May, 2019), tsanev (7th July, 2022)
