Page 44 of 51 FirstFirst ... 343940414243444546474849 ... LastLast
Results 646 to 660 of 752
  1. #646
    Jan 2018
    Quote Originally Posted by martom46 View Post
    znajdowany wsad do carprog wersji v8. 21
    https://www.360diag.net/a/downloads/.../1109/397.html
    tylko nie mam kodu aktywacji.
    może ma jej kalkulator do pomocy?
    jeżeli ma ktoś kalkulator lub może policzyć ?
    bardzo bym prosił o pomoc
    68766-D08B5-BE006-A91EB
    abc
    GKYRBZ4YHC5NFXUREUDLHECN5XRXFHLEPZRTRK5PVLTE6DCYQPVFKXPQ9JFR2Y6ZKJ
    Help = Thanks + Reputation Button
  2. #647
    Nov 2015
    Bulgaria
    please upload mcu firmware without at88 workng. i test with cp 4.01 without AT88.bin and work. Reason burnt at88
  3. #648
    Sep 2014
    poland suwałki
    Quote Originally Posted by 2m2c View Post
    AT91SAM7S256 bin for you
    hi I have problem with download dhis attached file can you 2m2c upload again?
  4. #649
    Sep 2015
    Poland
    For sirocco need a1+ adapter
    Wysłane z mojego SM-G920F przy użyciu Tapatalka
  5. #650
    Mar 2017
    Germany
    Can me anyone say how the steps to Dump a Carprog Flash File?
  6. #651
    Home
    is encrypted
    Keep in mind, English is not my native language.
  7. #652
    Jun 2018
    hello, is it safe to flash the carprog without removing the at88sc? without harm?
  8. #653
    Nov 2013
    Macedonia
    Quote Originally Posted by MrBingo View Post
    Hello
    I have flashed carprog more than 10 times without removing AT88SC and it is still working fine.
  9. #654
    gege974's Avatar
    Oct 2018
    réunion island
    should the wire 55 be resized on the pcb after reprogramming?
    Small circumstances produce great events : 02.47-tranquillité:
  10. #655
    Jan 2010
    Trstenik - Thun
    Quote Originally Posted by gege974 View Post
    Depend of HW version
  11. The Following User Says Thank You to mikroel For This Useful Post:
    gege974 (23rd October, 2018)
  12. #656
    Nov 2013
    Macedonia
    According to the datasheet, pin 55 can be left unconnected.
    ERASE Pin
    The pin ERASE is used to re-initialize the Flash content and some of its NVM bits. It integrates
    a permanent pull-down resistor of about 15 kΩ to GND, so that it can be left unconnected for
    normal operations.
  13. The Following User Says Thank You to Zann For This Useful Post:
  14. #657
    gege974's Avatar
    Oct 2018
    réunion island
    thank you for the information
  15. #658
    Aug 2018
    hi
    topic: JTAG programming for Clone Carprog
    I have bought CarProg and TL866ii PLus programmer with 10 Adaptors
    TL866 Link : https://www.ebay.co.uk/itm/USB-TL866...72.m2749.l2649
    and Carprog
    https://www.ebay.co.uk/itm/New-VSCAN...72.m2749.l2648
    I have searched on JTAG programmer and adaptors but It is very confusing as there are different ones depend on the MCU manufacturer.
    I do not have a serial port on my laptop. it is windows 10 with USB ports. Which cable do i need to buy.
    Please send a link for item in sale.
    Many Thanks!
  16. #659
    Nov 2013
    Macedonia
    If you want to reflash CarProg you can use J-Link
  17. The Following User Says Thank You to Zann For This Useful Post:
    Mustansar (9th November, 2018)
  18. #660
    Nov 2017
    Hi everyone! After reflashed carprog, I reconnect usb, but nothing happens..PC not found device. When erasing mcu pc found uknown device. Possible couse?
