Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
Hybrid View
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Default AUTOBOSS V30 HELP AND INFO THREAD
    thought this might be a good place to start a thread for others that need help and info on there autoboss v30 ie setup , using adaption codes , if and when new updates are available , cars its not working on and so on ,
    this isnt a place to talk about fakes and clones , even tho there made in china and sold here by agents
    user manual
    update client
    Sep 2008
    and if your a tight git and you have the printer attached,till rolls will work,use about 10 feet and wrap around the printers roller,note the text is small to read,strong glasses maybe needed.
    Mar 2008
    birmingham
    does anyone know if u still need to input the adaption codes in the newer Audi,s for the service resets or has the new updates added basic settings
    heres the manual settings on v30 http://autobossuk.co.uk/uploads/documents/51.pdf
  4. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    yvespapou (30th January, 2014)
    Mar 2008
    birmingham
    Remove/add limiter on 08-on , transit 2,4 is the v30 capable of doing this and anyone tried ? or does the pcm need updating on the later years.? cheers
  6. #5
    Mar 2008
    birmingham
    well mine came today .,. works great and 2 years free updates so thats ok . glad l didint get the printer .. its alot better printing from the pc on a4 paper ..
    cant say lm happy there isnt a battery back up in unit ? started an astra to see live data and the unit restarted ?
    but the scan all areas is good as the print out shows everything in one go ie: scans body abs engine the lot at once .. well on opel ayway
  7. #6
    Mar 2008
    birmingham
    Quote Originally Posted by smirnoff_rules View Post
    used on a 2009 transit today and set speed to 68mph .. worked great
  8. #7
    Mar 2008
    birmingham
    let me down today on a td5 discovery , didnt have suspension hight calibration , had to dust off my snap-on scanner to do it
  9. #8
    Mar 2008
    birmingham
    anyone used one of these 12 month upgrade cards ? l have 2 years left but wondered if they worked Autoboss V30 Sucurity Card For Product Update - Buy Autoboss Update,V30 Update Software,Spx Autoboss V30 Product on Alibaba.com $100 seems cheap
  10. #9
    Sep 2008
    maybe thats why jumper cables supplied,i had it on a vw passat trying to find a miss in engine it went through all the ecu ,but strange it found 2 engine faults,think i missed the getting the info out .
  11. #10
    Mar 2008
    birmingham
    Quote Originally Posted by cactikid View Post
    think lm used to the snap on unit havnt a battery ,, just undated it and updated to new dash aswell but havnt tried yet , will test monday
    interesting reading on injector coding injection codes
  12. #11
    Top Poster rrob311's Avatar
    Jul 2010
    Ya that happened to my Beetle. I would just use the cigarette lighter adapter with a jumper pack or just leave the ac adapter plugged in. I was able to reset my throttle body and get the beetle running but it was difficult to navigate the factory settings without knowing what is what.
  13. #12
    Mar 2008
    birmingham
    have to say after having for a few weeks now im very happy with this unit .. its better than my snap on scanner
  14. #13
    daniersms's Avatar
    Feb 2010
    South Africa
    Yes I think some people under estimate the Autoboss---mine works great
    Love this forum
  15. #14
    DK Veteran 54321's Avatar
    Feb 2010
    Trying to update mine at the moment and keep getting this message and it won't update:
    'certain program download failed, please try to select only this and download.'
    Has anybody experienced this?
  16. #15
    May 2013
    Quote Originally Posted by 54321 View Post
    did you use windows 7 to download it?
    you need windows xp to do that. i got this problem too.
