Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 108
Hybrid View
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Default Launch X431 INFO AND HELP SECTION
    thought this might be a good place to start a thread for others that need help and info on there LAUNCH units ie setup , using adaption codes , if and when new updates are available , cars its not working on and so on ,
    NO TALK ON FAKES OR FAKE SOFTWARE PLEASE
  2. The Following 3 Users Say Thank You to smirnoff_rules For This Useful Post:
    Amdx (17th May, 2021), Marido71 (19th January, 2019), Mee?kat (13th April, 2014)
  3. #2
    Member demodamota's Avatar
    Aug 2010
    hello , I have a original launch mini "PDA" and works perfect at 10 days ago . The SD card have lost all the information and now I cant do anyting My last update are from 2008 .Someone can tell me please if possible repair the SD card or I need to buy new one ?
    tks in advance
    Mar 2008
    birmingham
    when you put the sd card in a pc does it say the card needs formating ? if it does it sounds like its corrupted and the software might be there ? there are programes on the net that can remover deleted stuff of a card , might be worth a hunt around ..http://pcsupport.about.com/od/filere...y-programs.htm
    :~)always copy your sd card to pc as a backup after any update
    May 2010
    NL
    Hi Smirnoff
    I have an problem with 2 X431 the are very very slow after update send from china somebody an suggestion
    the last other I did tel me ::
    Reset smartbox OK
    Checking smartbox Succes
    Download program Failure
    some suggestions are welcome thanks in advance
    regards T
  6. #5
    Apr 2010
    Quote Originally Posted by Tachotony View Post
    Hi Smirnoff
    Reset smartbox OK
    regards T
    sorted out?
  7. #6
    Dec 2011
    intall any cd card!!!
  8. #7
    Oct 2012
    Hi please i have a probmlem with my lanch i can't accees to the
    bluetooth connection or cable when i click on bluetooth or cable he gives me this message
    the application has performed an illegal operation and will be stoped.if the problem persists contact the program vendor
    Program: Diagunshow.exe
    Exception : 0x0000005
    Adress: 56004F00
    I really need u'r help and thx in advance
  9. #8
    Apr 2010
    Quote Originally Posted by salahmanu View Post
    Adress: 56004F00
    Will you backup your card and format the card and drag the file back to the card again and then test it?
    if it still can't sorted out,you may have to contact your supplier
  10. #9
    Apr 2010
    Czech Rep
    Hello all,
    I bought Diagun before any time. All works good, but how or where I find if is clone, or ori?
    Is any database?
    And where I find username and password for login to X431 sites?
    Many thx
    Matias
  11. #10
    Apr 2010
    Quote Originally Posted by matias View Post
    Hello all,
    Is any database?
    Many thx
    Matias
    the simplest way is to see your manual,if the manual language in Chinese,that would be 100% clone.haha...
  12. #11
    Oct 2012
    Hi i have a problem in the screen of my launch x431;however i calibrated it in the start the problem persist it start very well in the begening but after a while the problem appears and i can't work with the stylo or the pen i must keep the click on something for a while to chose please any idea or help please
  13. The Following User Says Thank You to salahmanu For This Useful Post:
    tomdiag (15th December, 2020)
  14. #12
    Nov 2010
    nanuet ny
    KINDLY LOOKING FOR HELP TRY TO TROUBLESHOOTING PROBLEM WHIT MY X431 TOOL
    the machine works in almost all the brand, the only one that can not connect seems mercedes specially older 38 pins , and when connected besides error communication , is produce lots malfunctioning in the especially in the traction control , is erase the codes in all the units end generate communication problems between modules , can really verified because do not have another scanner capable but after try to communicate the BAS light indicate malfunctioning and than goes way , any idea . is the smart box , the 38pin or software> any input is appreciate , thanks
  15. #13
    DK Veteran NZBrakelathes's Avatar
    Aug 2010
    Zibo Shandong China
    Quote Originally Posted by vicaro View Post
    Is your unit a true Launch or Copy?
  16. #14
    Jul 2016
    Hi I have a launch x431 v+ and it works well
    But it can't do any coding on ssangyong
    It reads and erases Dtc well.when I go to injector coding it seems like coding but nothing changed....thanks for the thread.
  17. #15
    Aug 2016
    : Good day everyone. that someone tells me how to program the VDO461470002004 Renault 220dci.et Thank you very much avence
