Overclocking is not recommended on a laptop. First of all the overclock would be limited and then there's the extra heat, not to mention that it won't make a blind bit of difference in all honesty.
I'd suggest you try logging in from a family or friend's PC that has dedicated graphics hardware acceleration and see if the stuttering stops. If your CPU is at 100% then that is definitely what you should try to eradicate first.
Smart dns does not affect your broadband speed or ping and it will only work on certain sites supported by overplay, all it does it route the inital connection to admc via there server as far as im aware this is only done once with that website.
It will work slightly differently with sites like foxsoccer2go as they constantly check ip addresses for geoblocking this how ever will not effect the download speed or ping on your home connection as its all done at the end.
well im watching liverpool game now and the pic is bad its like the pixelation is not clearing fast enough
Tried to upload pic but can not from my iPad
It's the same for me. You can make the picture out, but when the camera angle gets changed or there is a fast bit of play the picture is pixelated.
TBH I turned the match off in the 26th minute, wasn't worth it after that!
I am having a lot of problems with my Internet ATM, which I have only just realised, so I'm hoping once that is fixed the picture should be ok. I just need a new laptop!
I TRIED IT AT 2 ADRESSES and same we both on bt home hub 3.0
i was getting ace pic 1st 2/3 weeks now gone bad tried everyting to improve it it would be better if you could pick what stream you wanted eg low-med-high
Hi, has anyone tried watching through a media player? I was thinking of getting one & trying it but I do not know if you can put the smartdns on them.I've had a look at the "WD media player" & I'm not sure if it will support the smartdns as it says on it's site "DOES NOT SUPPORT PROTECTED PREMIUM CONTENT". Anyone know anything about it? Thanks in advance.
"File Formats Not Supported Does not support protected premium content such as movies or music from the iTunes Store, Movielink, Amazon Unbox, and Vongo"
Does this site show all 380 epl matches
Did u use a vpn to sign up got the apps already
Well BT do have a vested interest in streaming premier football - and it will get stronger.
