Results 1 to 11 of 11
Thread: citroen c4
    Default citroen c4
    55 reg, 1.4 petrol, problem is on startup revs stop at 1500rpm. plugged in diag, faults are map sensor, in live data shows 0, changed map still the same, done pinouts to ecu all wiring fine. i have checked voltage at map sensor according to autodata. it says there is a 5v, gnd, 4v. i am missing the 4v so i suspect ecu fault, can i use second hand ecu or does it have to be new, numbers on it : iaw 6lp2.05. thanks
    Jun 2012
    Brasil
    yes you can use another used ECU and immobilizer swap file, that has a central processor st10 vc copies banks 1 and 2 for the immobilizer
    Sep 2012
    x prog m red flash st10f good.
    i have a xprog m, do you have a wiring diagram of were i have to solder to to read st processor. thanks
    Ashraf6119's Avatar
    UK
    Have you checked if there is no any leak in Intake System...
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    obdmaster's Avatar
    Never never land
    Wink
    Quote Originally Posted by radiosolutions View Post
    Id image the 4v is a signal from map sensor to ecu???,
    So replacing ecu, wont fix, as youve changed map sensor, check for air leaks as ashraf says. if all good cut wire coming out of map sensor and test voltage again, as wire to ecu may be down to ground in loom????
    You need every tool in the book, to do this auto locksmith job.
    Jun 2012
    Brasil
    I have a link that you need the files and calls me on msn I'll step coordinates
    mario hugs
    no addys
    a bit of feedback, i disconnect camshaft sensor and voltage then was right at map sensor, 5v, 4v, gnd. problem was the camshaft sensor, its on the same line as the map sensor 5v. it was shorting out therefore bringing the voltage down on map sensor. the camshaft sensor is located behind air filter box coming off throttle body. thanks for all help.
    alclot's Avatar
    Melee Island
    Hi mates,
    I´m looking for wiring about this marelli ecu. Can anyone help me with that please?
    Thanks in advance
    alclot's Avatar
    Melee Island
    Hi mates again. I have this pinout but I need to know pins where is the can-bus. Can any good samaritan help me?
    Thanks in advance
    Pins A-3,A-4 on plug C,next K line
  12. The Following User Says Thank You to synkrotronic For This Useful Post:
    alclot (11th July, 2018)
