is there a dchp option?
I have an itgate TGM220. So the ethernet connection is not working on my box. I no it the box cos i have an other box and connected it up and it work fine. I went to retrieve ip and it said no Internet connection. Anyone come across this issue be four and any help would be grateful.
Maybe an image/driver issue...i would reboot everything and if this does not sort it i would reflash with the v9 and see what happens.
good luck.
Thanks for the info, I'm gone to work so I will try tomoro and update then.
Give the itgate a static ip address, if you have wireless pc, phone etc. in house there could be a conflict in ip addys.
Cheers,
bugsy.
Got it back working its on uk V-9,Gave it a factory reset and it worked,cant get ccam on it so going to try other image and will report back
give me a shout If your struggling i have a v9 back up with cams,just edit you cfg file.
Deeboi cpanel still works via blue button, with 2.14 ( bin+cfg) avalible
Hi guys , will be doin a post later containing the images I have got working for the tgm 220 there's a few there hopefully help a few peeps out
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk
I got the box working.I used deedoi image from 27th Jan 2012, Thanks.It was the only image that showed up when i ftp to the tmp folder,Watching the Ryder cup now so happy out.
