ethernet connection not working
Results 1 to 11 of 11
    Default ethernet connection not working
    I have an itgate TGM220. So the ethernet connection is not working on my box. I no it the box cos i have an other box and connected it up and it work fine. I went to retrieve ip and it said no Internet connection. Anyone come across this issue be four and any help would be grateful.
    Nov 2008
    on earth
    is there a dchp option?
    May 2008
    Maybe an image/driver issue...i would reboot everything and if this does not sort it i would reflash with the v9 and see what happens.
    good luck.
    Thanks for the info, I'm gone to work so I will try tomoro and update then.
    Top Poster bugsy's Avatar
    Feb 2009
    Give the itgate a static ip address, if you have wireless pc, phone etc. in house there could be a conflict in ip addys.
    Cheers,
    bugsy.
    Got it back working its on uk V-9,Gave it a factory reset and it worked,cant get ccam on it so going to try other image and will report back
    May 2008
    give me a shout If your struggling i have a v9 back up with cams,just edit you cfg file.
    V.I.P. Member haribo's Avatar
    Jun 2008
    in my car
    Quote Originally Posted by phat1 View Post
    you just need to manually add it, rather than try using the cpanel, it will work fine
    May 2008
    Deeboi cpanel still works via blue button, with 2.14 ( bin+cfg) avalible
    Top Poster Millzzy's Avatar
    Hi guys , will be doin a post later containing the images I have got working for the tgm 220 there's a few there hopefully help a few peeps out
    Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk
    I got the box working.I used deedoi image from 27th Jan 2012, Thanks.It was the only image that showed up when i ftp to the tmp folder,Watching the Ryder cup now so happy out.
