Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 79
  1. #16
    Vasily.U's Avatar
    Belarus Minsk
    This programmer not support 95p08
    What tool you have?
  2. The Following User Says Thank You to Vasily.U For This Useful Post:
    Renovator (15th February, 2020)
  3. #17
    Vasily.U's Avatar
    Belarus Minsk
    In this ecu you can read and write 95p08 without desoldering in boot mode via k-line
    Use this program with k-line adapter
  4. The Following 2 Users Say Thank You to Vasily.U For This Useful Post:
    gabex (12th February, 2018), Renovator (15th February, 2020)
  5. #18
    Jan 2017
    Here an other one with "microchip" choose this is 1 kb
  6. #19
    Jan 2017
    Ihave only mpps v16, and this is can read only the flash unfortunately
  7. #20
    Jan 2017
    Thank You so much, I'll try
  8. #21
    Vasily.U's Avatar
    Belarus Minsk
    95p08 not same 95080 and 25080, another bad read
    See post 17
  9. The Following 2 Users Say Thank You to Vasily.U For This Useful Post:
  10. #22
    Jan 2017
    Quote Originally Posted by Vasily.U View Post
    See post 17
    Thank You so much, I soldaring back, and I w'll try
  11. #23
    Vasily.U's Avatar
    Belarus Minsk
    And in your flash dpf and immo already off)))
    I read about your problem all your posts and i see your problem not immo.
    In your flash immo off and immobilizer fault message must be always but the car will start.
  12. #24
    Jan 2017
    I have DPF, it's working
    I have immobilizer error message in the ecu (can't erase) not only on the dashboard, and no live data , the car no running
    I tied to read eeprom with, mpps, with kwp2000+, but nothing, did't find it
  13. #25
    Vasily.U's Avatar
    Belarus Minsk
    What diagnostic tool you have? MPPS and kwp2000 can't read eeprom, use k-line adapter for it. In your flash dpf 100% off and immo 100% off. Is number on label on ecu 0281010765? Ecu have 3 plugs? Original soft for your ecu
  14. The Following User Says Thank You to Vasily.U For This Useful Post:
    gabex (13th February, 2018)
  15. #26
    Jan 2017
    I have still VAG COM, willem programmer no more
    Yes correct. 0281010765 with 3 plug
    Thank You I try this
  16. #27
    Vasily.U's Avatar
    Belarus Minsk
    And than you diagnose the car?
  17. #28
    Jan 2017
    with MVdiag / Cars cdp+
  18. #29
    Vasily.U's Avatar
    Belarus Minsk
    what version vag com you have?
  19. #30
    Jan 2017
    409.1 KKL VAG-COM
