Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 79
  1. #31
    Vasily.U's Avatar
    Belarus Minsk
    409.1 KKL VAG-COM=kk-l adapter. You can use it with program from post 17.
  2. #32
    Jan 2017
    Quote Originally Posted by Vasily.U View Post
    What diagnostic tool you have? MPPS and kwp2000 can't read eeprom, use k-line adapter for it. In your flash dpf 100% off and immo 100% off. Is number on label on ecu 0281010765? Ecu have 3 plugs? Original soft for your ecu
    I tried Your original file , but the same problem, no live data and in the engine error P1517 (immo)
  3. #33
    Jan 2017
    Yes I tried, but always get error message the ecu not respond.
    pin7: K-line
    Pin4: ground
    Pin 16,13 12V power
  4. #34
    Vasily.U's Avatar
    Belarus Minsk
    Ecu must be in bootmode.
    1. Power off
    2. Bridge 24 pin 29f400 to ground
    3. Power on
    4. Wait a few seconds and remove bridge
    Ecu in boot mode
  5. #35
    Jan 2017
    ohhh. Thank You I didn't know this before ...
  6. #36
    Vasily.U's Avatar
    Belarus Minsk
    Connect like picture
  7. #37
    Jan 2017
    ohh okay same like the ecu flash, I understand now....
  8. #38
    Vasily.U's Avatar
    Belarus Minsk
    Usualy i do it on a car
  9. #39
    Jan 2017
    error again
    Starting Boot_mode ... uC ID response 0xAA. Unknow ID. (error=0x40201)
    closing COM7
  10. #40
    Vasily.U's Avatar
    Belarus Minsk
    printscreen?
  11. #41
    Jan 2017
    printscreen?
    I got a photo
  12. #42
    Vasily.U's Avatar
    Belarus Minsk
    It's very strange, i use it many many times without problem. In your screen not right processor id. May be need change latency to 1 ms in com port settings. And in some vagcom adapters k-line voltage not 12v but 5v
  13. #43
    Jan 2017
    right now I got it an different error message
  14. #44
    Vasily.U's Avatar
    Belarus Minsk
    try don't remove bridge
  15. #45
    Vasily.U's Avatar
    Belarus Minsk
    i use k-line on ftdi chip and all ok
