Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 79
  1. #46
    Jan 2017
    Quote Originally Posted by Vasily.U View Post
    try don't remove bridge
    nothing, same like before
  2. #47
    Jan 2017
    i use k-line on ftdi chip and all ok
    ok. Thank Your for your help, and this lot of time!!
  3. #48
    Jan 2017
    Goal!
    I bought an FTDI chipset Vag, and it's working! )
    I read the eeprom .
    Please see it..
  4. #49
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  5. The Following User Says Thank You to kiszka For This Useful Post:
    gabex (21st February, 2018)
  6. #50
    Jan 2017
    Quote Originally Posted by kiszka View Post
    pin ...7C0T....
    thank you, but i can not learning key with this code, i have MVdiag but when i give this code i get error message
    i need immo off
    how can i put this code to the flash dump? see #10 post
  7. #51
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
  8. #52
    Jan 2017
    READ eeprom bsi
    I read with ponyprog but is empty...
  9. #53
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
  10. #54
    Jan 2017
    read eeprom is bad
    yes, i think. i take it to an electric man, tomorrow I will be an good read bsi dump ......I hope... unfortunately I have no programmer to read and write this type of eeprom
  11. #55
    Jan 2017
    The other reading is the same... I try something else, or the chip is bad
  12. #56
    Vasily.U's Avatar
    Belarus Minsk
    I repeat in your flash immo already off
  13. The Following User Says Thank You to Vasily.U For This Useful Post:
    gabex (26th February, 2018)
  14. #57
    Jan 2017
    Thank You!
    The BSI eprom is garbage.No data on. Nothing.
    What can I do it? I put it one new chip inside, with filled FF? or with new virgin eeprom files?
    And after? You say my flash ( I think the flash is the AM 29F400BT chip) is off. That's good, but I need to immo of the 95p08 chip too? (for example with immo service tool 1.2) or enough the flash off, and re learning the BSI with PP2000? Sorry but Im very study still...
  15. #58
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
  16. #59
    Jan 2017
    read eeprom ecu
    Hello.
    is at the post #48
  17. #60
    Vasily.U's Avatar
    Belarus Minsk
    Quote Originally Posted by gabex View Post
    Thank You!
    Yes , in edc15c2 3 plug immo off in 29f400, in your ecu in flash immo off and dpf off . You can try this eeprom but i'm not sure problem in immo.
  18. The Following User Says Thank You to Vasily.U For This Useful Post:
