Results 1 to 12 of 12
    Aug 2010
    Belarus, Bobruisk
    Default Opel Zafira 2003 Y20DTH PSG16 need pin from dump
    Hello friends!
    Need your help. Car Opel Zafira 2003 Y20DTH PSG16 swap Pump. I read the dump from the pump through Carprog clone and now I need the correct pin to make reset.
    Pin 2323 - wrong!
    The data from the diagnostics:
    VIN: W0L0ZCF6838056005
    vehicleManufacturerECUHardwareNumber 24451346 KD
    systemSupplierECUHardwareNumber: BOSCH010000001401
    systemSupplierECUHardwareVersionNumber: 0000
    systemSupplierECUSoftwareNumber: DJAMS120_S
    systemSupplierECUSoftwareVersionNumber: 0774
    exhaustRegulationOrTypeApprovalNumber: B02008
    systemNameOrEngineType: Y20DTH
    Thanks in advance for any help.
    topclef's Avatar
    Pin 2323 IS CORRECT
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
    Aug 2010
    Belarus, Bobruisk
    OP-Com: Engine->Programming->Reset ECU Login: 2323->Login incorrect->Op-Com Diag Engine-> P1611 - Login wrong + activated wait time
    OP-Com: Immo(Immo alredy Reset)->Special Functions->Login: 2323->Reset ECU->Login incorrect->Op-Com Diag Engine-> P1611 - Login wrong + activated wait time
    Car-Prog: Login: 2323->Reset Pump->Op-Com Diag Engine-> P1611 - Login wrong + activated wait time
    What are some other ideas?
    Aug 2010
    Belarus, Bobruisk
    Who can to VIN-number to find out information about the car. Maybe this pump Opel Vectra-C.
    Estonia
    If you want to install Zafira pump to Vectra, then the pump must be reseted on Zafira. You can not reset Zafiras pump on Vectra-C!
    W0L0ZCF6838056005 = Y20DTH engine. Its a Vauxhall.
    I dont think that is posible to get work vectra C pump on zafira.
    bursuc's Avatar
    Oct 2011
    inside MCU
    i read somewhere , you can reset it on bench , and it will work...search the forum m8
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
    DK Veteran zoro1's Avatar
    Bulgaria,Sofia,Vidin
    yes you can do it on table,or on car with carprog.see on carprog page there is shematic how to connect pump and OBD2 cable.You will need relay 12V 3A and swich.
    Large nations behave like gangsters ,and young as prostitutes !
    Senior Member kardi78's Avatar
    Sep 2012
    Hungary
    Hi, Clone carprog "opel / ECU / can bus" not working!! This will surely say, because I tried several models. The download mark in just bounce on and not connected to the ECU.
    I have put Vectra C psg16 pump into Zafira A. The Bosch number was the same, but it had to be replaced and the software reprogrammed.
    With original carprog the reset not problem, but maybe After mounting, the Zafira A, it will seek companions CANbus, such as UEC, REC, CIM ...... , try to find someone near you who is original and carprog and you doing reset on table, after put into the Zafira A, then update the software that the car should be.
    Otherwise the pin 2323 may not be bad, but does not allow to recover the OPCOM as the Vectra C CANbus system and the Zafira A K-line.
    If deprogrammer and Zafira models you will not find a CANbus companions.
    Mar 2012
    chile
    hi i need please you help dr menbers for conect the ecu m.1.5.5 of corsa city with the carprog
    i need the pin to read the ecu please
    Sep 2012
    Hungary
    connecting it to the OBD carprog for, selecting the k-line folder m1.5.5 bosch software, and then "read all" principle reads the content and get the correct PIN
    if not, the Chinese can not clone it!
    Hii, necesita código PIN psg16..thanks
