CCcam - Error Reading Webpage
Results 1 to 5 of 5
    Oct 2012
    Default CCcam - Error Reading Webpage
    I have a VU Plus Duo, running VIX image and enigma CCcam, latest version.
    Whenever I access the cccam info, I get "error reading webpage"
    What error have I made in the setup?
    I cannot view any channels.
    I have a UK bouquet loaded.
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Press blue button sc manager then enable.
    Oct 2012
    It is enabled and also switched on to load each time.
    I changed the cccam image, now using 2.2.1 and the channels are working.
    Still cannot use cccam info, any menu I go into results in "error reading webpage"... as if the cccam cannot access anything. I read something somewhere about telling the cccam info program what your IP address was. Any ideas?
    Feb 2012
    Is anyone found any solution for error reading webpage problem? My cccaminfo also creates the same error.
    DK Veteran lincsat's Avatar
    Jun 2008
    Corrupt config maybe?
