Hi everyone.
Can somebody pls share/upload the current picons for E2 boxes?
Thanks in advance.
Hi Thank you for the post, is this installed via the add on manager. Hope its not a silly question but I am new to deambox? Thanks
I've downloaded this plug in, but it takes a long time to run, and doesnt change my channel order. Can anyone help? Should I delete my own bouquets first before scanning? Can someone help an idiot out please.
Hi guys, sorry to bother you with a stupid question. I'm new to all this & can't find Sky Box Office on my channel list. I have a VU+ Duo with Enigma2 and VIX software. Not sure how to set up Bouquets & I'm getting really frustrated with it all. Can someone offer some advice please?
If using the original plugin, then update to the March 2013 release, it's much faster. When done, try restarting Enigma to see the changes. The new Bouquets will be at the start of the list (Assuming you've told it to generate a default set), you can then delete the older bouquets.
On BH, the Autobouquets generates a Sky Box Office bouquet, I would think it's the same on Vix.
Fantastic results on a dm800hd, installed and scanned within 5 minutes. Kept my sgt flipflop bouquets but not really needed as these are in sly order. Thanks again.
Hi, i tried the enigma2-plugin-extensions-autobouquets-e2_201303010205_mipsel on dreamboxuk 2.1.2 on a DM800HD and it works fine and scans quick, only 1 issue when i click custom channel swap to yes, so i can get itv hd , channel 4 hd , channel 5 hd first, some reason the 101 - is BBC Alba ? even when i selected wmids hd ? when i turn off Custom Channel Swap . its correct bbc 1 wmids, but of course then dont get hd channels of itv , channel 4 and 5 ? anyone help ?
top plugin
local channels have moved positions since plugin release, edit your /usr/lib/enigma2/python/Plugins/Extensions/AutoBouquets/custom.txt file with a unix/linux compatible text editor to read:
101=141
102=142
103=178
104=230
105=171
lombard (11th April, 2013)
hi, been using this plugin it for months now, works great.
Just having 1 problem I hope someone can help me with. I have added some channels (mtv trax, irish ones) using the supplement file. This worked as expected, i added them to spare numbers 992-995.
I then wanted to swap these channels. I edited the custom text file, and for example added the line 168=992. But this did not work. The custom swap worked fine for channels 101-105, they swapped no problem, but none of the supplement added channels would move, they stayed in the 992-995 area.
What am i doing wrong?
you cannot swap channels with blank channel numbers using the custom.txt file.
you need to directly insert channels into blank positions 168, 169 using supplement.txt file.
supplement.txt ( 168 = 00a8, 169 = 00a9 ):
00a8:1255:01:2585:07fb:11a0000:BSkyB:NDS:TV3
00a9:4693:01:cb87:08fd:11a0000:BSkyB:NDS:3e
ok thanks for the reply, but i thought i read somewhere that doing that would upset the sky epg numbers, that they all get shifted by one, so say sky sports 1 moves from 401 to 402, or is this not the case?
If you corrupt the database, just delete the bouquets and scan again - that usually fixes it.
ok so i have a brand new box, blackhole enigma 1.79. all i do is channel scan then install this addon in order for it to work? how do i ftp is there a set ip and password?
