Page 3 of 24 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 346
  1. #31
    May 2008
    Quote Originally Posted by lincsat View Post
    The only Interactive channel left is on 10773 H 22000 5/6, you may have to do a fresh scan to update lameDB or Lraz may have to modify the script for the change.
    OR you can modify the script yourself!
    change epg to 2051 on line 447:
    				"2051")
    					bouquetname "12" "BBC Interactive"
    and also change epg range to 2050-2053 on line 667:
    		if [ $epg -gt 2050 -a $epg -lt 2053 ]; then
    			ca="FTA"; sn="BBCi $epg"
    run plugin to create latest BBCi bouquet
  2. #32
    Nov 2012
    hi all new here, this sound like just what i need
    Quote Originally Posted by DMBoot View Post
    Originally posted on on SGTFlipFlops SKYUK Bouquet thread.
    I still feeeling my way around this plug-in, but it seems great so far .......
    I can highly recommend AutoBouquets E2 28.2E
    Updates your E2 box with Sly numbered bouquet set specifically for YOUR region. You set your region in the menu.
    I've mine set to "Northern Ireland HD", so I get the BBC and ITV channels downloaded for NI and it means I also get the ROI channels on 161, 162 & 163. No editing required.
    It can be tailored to only download specific bouquets and can be scheduled to run overnight.
    Fantastic plug-in if you want regional Sly numbered setup without the need to modify existing bouquets.
    It bascially fully automates the Sly numbering and automatically keeps it up to date. I'll be using SGTFlipFlop's non-Sly bouquets to compliment the auto bouquets though.
    Options for AutoBouquets E2 28.2E
    Use HD First Bouquet
    Puts the HD channels starting at position 6 immediately after 1-5 (BBC1, BBC2, ITV1, C4, C5 for your region).
    Show Channel Numbers
    Puts the channel number in front of the channel name. ?104 ? Channel 4?, instead of ?Channel 4?.
    Use Internal NIT Scan
    Doesn?t seem to make any difference? Finds new/modified transponders. It doesn't seem to make any difference because the transponders rarely change. The only changes in the last few months are the BBC HD transponder changing to 8PSK, C4 HD transponder changing back to DVB-S, the Olympic transponders closing, and a couple of switches to HD.
    Use Pli Placeholders
    Only works on images using an OpenPLi base. It skips the placeholders. If set to YES, it doesn?t keep the Sly numbering on my DM800HD SE running Dream Elite 3. Works on VIX on my Duo.
    Create Child Friendly
    Guessing it parental locks some bouquets
    Make Default Bouquets
    Custom Channel Order
    Allows you to re-order the Sly channels?
    Scheduled Update Scan
    Runs the plug-in at the specified time
  3. #33
    Member colinh1213's Avatar
    Apr 2011
    liverpool
    tried my nut off today to get this working yet i cant get any options for the plug in , and then my box crashes , any clues guys?
  4. #34
    cheers for this it works really well on my vu solo can you tell me is there an enigma 1 one that will also auto update thank-you
  5. #35
    Nov 2012
    looks good this usable on other enigma2 boxes ?
  6. #36
    Oct 2012
    Quote Originally Posted by DaHoncho View Post
    Yes it is.
  7. #37
    Feb 2012
    thanks for posting this up - will try on my blackhole box. This now replaces the need to manually update channel lists & bouquets?
  8. #38
    Member SparkyUK's Avatar
    Nov 2008
    Wilts
    i tried this plug-in, I had to reflash my box.
    Im using dreamboxuk firmware.
  9. #39
    Newbie Huds78's Avatar
    Nov 2012
    Quote Originally Posted by SparkyUK View Post
    Oh I was going to try this on my DM800HD but not sure if I want now ??
    When I go to about on my system it says :
    Enigma : 2011-07-06-experimental
    Image :Newnigma2-unstable 2011-08-26
    This don`t mean nought to me but do you think it would work on my box ?
  10. #40
    Sep 2008
    i've just installed it on my DM800HD and it's working ok. it took about 45mins to sort the bouquets
    DM800HD PVR clone
    90cm dish - motorised
  11. #41
    Oct 2010
    LIVERPOOL
    Unhappy crashes
    hi all, installed autobouquets e2, on my dm800 hd pvr box. when i try and start it tells me to press menu to setup, but after pressing menu the box just crashes and reloads, any suggestions, thx mac
  12. #42
    Sep 2008
    hi, how much memory do you have available on your box.
    everytime i went into a menu and tried to come out again my box would crash with a green screen message saying not enough space so i reflashed it and now i have 13mb free space out of the 60mb total space available and it's all working ok now
    DM800HD PVR clone
  13. #43
    Oct 2010
    LIVERPOOL
    Unhappy
    hi, not sure how much memory on the box, but it's no error message saying memory, just says "we are really sorry your dreambox encountered a software problem", blah blah blah, then reboots and comes back on. thx
  14. #44
    Sep 2008
    you would normally see this at the top of the screen
    Quote Originally Posted by macbow View Post
    but if your quick enough you can see what the error says at the very bottom of the green screen but you only have a split second to see it.
    mine happened to say "not enough space on device".
    do you have tspanel installed. if you have you can go into:
    tspanel/information/freespace
    and it will tell you how much free space you have
    DM800HD PVR clone
  15. #45
    Oct 2010
    LIVERPOOL
    Unhappy
    after reading more on this, thinkin its to do with the image i got, blackhole v12, with kernel 1.5 which is apparantly old and wont work, need an updated image past may 2010, for this to work
