Page 14 of 24 FirstFirst ... 4910111213141516171819 ... LastLast
Results 196 to 210 of 346
  1. #196
    Sep 2011
    hi i have just downloaded this and its working a treat, can you have it without the sky channel numbers i.e. bbc1 is 1 and bbc2 is 2 etc
    cheers
  2. #197
    Jun 2012
    Can anybody help me? when i try and run the autobouquets NIT scan it says:-
    /bin/sh:
    /usr/lib/enigma2/python/plugins/extensions/autobouquets/autobouquets_e2.sh: Permission denied
    Execution finished!
    I noticed people saying to change the permissions to 755 etc, i havent a clue how to do that? can somebody help with that? where is the option or notepad to change the permissions?
    EDIT:
    Managed to get it going! thanks!!
  3. #198
    Jul 2013
    Ok I need some help...
    I have downloaded this....but there is no guide of how to install....someone please help!
    manage to do this now.....
  4. #199
    Jul 2013
    thanks is this pretty good but need help on 1 more thing
  5. #200
    Jul 2013
    Quote Originally Posted by LraiZer View Post
    1) yes, the adult bouquet is disabled by default when you install the plugin. you need to enable the adult bouquet in the plugin options to create it.
    2) yes, you can move bouquets and still retain the official channel zapping numbers. the following options are required to allow this.
    Use HD First Bouquet = no
    Make Default Bouquets = no
    3) yes, set option Custom Channel Order = yes, and edit custom.txt file in AutoBouquets plugin folder. the example custom.txt file is already set to replace bbc1,itv1,channel4 as these are FTA channels. you will have to look to edit the custom.txt file to swap channel5 and any other channels.
    where can i find this custom.txt file....where can i find the plug in folder?
  6. #201
    Jul 2013
    Would this apply for a Sunray 800HDSE?
  7. #202
    digicon's Avatar
    Quote Originally Posted by kevinbann View Post
    The Autoboquets will work on any Enigma2 box Mispel based, Please remember this only sorts channels at 28.2? east and nothing else
  8. #203
    Jul 2013
    do i just add this as a pluging?
  9. #204
    digicon's Avatar
    Quote Originally Posted by 77ste77 View Post
    The instructions for installing should already be known to every Enigma2 receiver owner if not i suggest you read some of the Guides in the Dreambox section, Also look at the second post of this very thread for how to install
  10. #205
    Feb 2012
    Will this automatically update new channels when they move or do I need to start the app manually?
  11. #206
    Feb 2012
    god 40mins and STILL updating...
  12. #207
    Feb 2012
    Finally done after 45 minutes, but my old boutiques are still there, and the new ones there is a lot of gaps in between channels with nothing example 242 discovery shed, but then 243 244 245 are blank any ideas why?
  13. #208
    digicon's Avatar
    Quote Originally Posted by MW35 View Post
    And thats because it follows the $ly channel numbering sytem so after 242 next channel should be 246
  14. #209
    Feb 2012
    Thanks for your reply is there a way is there a way to do it without getting gaps between the channels? Also how do I delete the old boutiques?
  15. #210
    digicon's Avatar
    To remove the channel gaps you will have to alter the script that auto bouquets runs there is a giude or a post somewhere on the forum that explains this, As for the bouquets maybe delete everything first and then start a fresh
