Thanks a lot for your info, my friend
Just 28.2? east Only if using the Vix image they have ABM which has options for other satellites, Or you could use the Vhannibal Autoupdater: http://www.digital-kaos.co.uk/forums...plugin-413614/
In Almighty God I trust, everyone else has to provide evidence
can i use this with an skybox f5? thanks in advance debs
New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Me2 (24th August, 2014)
Installed and run for the Granada SD region but I get BBC ALBA at channel 101 any ideas why?
Similar problem to any-mgzt. 104 is mapping to UK Living instead of Channel 4 HD. I have tried this with London SD and Essex SD locations. Problem is occurring on both my Vu+ Duo and my Vu+ Solo SE. Any ideas why?
How do I keep the channel list the same as I've got it set to at the minute.
Normally it moves everything to make the same as sly.
Ηι with DM800HD SE clone running Open Pli 4, I'd like to install AutoBouquets E2 plugin.
I went to Menu-->Setup but I don't see-->Software Management-->Install local extension
So what is the right move to have the AutoBouquets E2 plugin?
Thank you in advance
Harry.
Updated files from 13th November 2014 added to first post
I can't uncheck the "FTA only" option. I can check and uncheck all the other options.
Anybody seen this?
I had to install manually and set a few files to 755. It's like it's a write access issue.
cheers
hi guys my niece has vu+solo2 box with autoboquets,where can I find a channel list update for it.
any advice will be greatly appreciated
hi mate have a look here http://www.digital-kaos.co.uk/forums...uets-amp-Skins i use catseye list try a few c wats suits u best cheers shaun
Could i just remind all Forum Members that we have a 'Thanks' button located in the bottom left hand corner of every post, Please use this instead of the Usual 'Thanks XXXXX for this'
These type of posts just clog up the forum and take up valuable server space which could be used for something else
Thank you very much for understanding
00360362878 (3rd June, 2015), wxm14 (1st May, 2015)
hi im looking for the latest bouquets for a dreambox 500s astra 28.2e im based in ireland but the UK is ok sorry im using open PLi
