many thanks for this
I tried this earlier today for the first time.
It installed straightforward enough, and the front end works fine. However, when I went to start the scan, it gave me the following error "wget: cannot connect to remote host (127.0.0.1): connection refused".
I know it must be something obvious but I am not clued up enough to find the issue myself.
ANY help much appreciated.
CHEERS
Hi, can anyone help out with the above issue. I would really like to get this working if at all possible.
Thanks.
i looks like you would be required to use the files in the debian folder if you were creating a new .ipk installer with any modifications to the plugin so that the original author's maintainer details are in the new installer package that you created.
maybe you disabled the web interface in the settings somewhere or you have removed an OpenWebif plugin? you may have either no webif installed or you may even have two different webif installed, a built in one and a self installed OpenWebif and both are enabled?
An absolutely brilliant plugin!!!
Yep class plugin, really works well, saves us from finding all the versions of local stations.
Try overwriting your \usr\lib\enigma2\python\Plugins\Extensions\AutoBou quets\autobouquets_e2.sh file with the one in this archive. This one may work for you because all the error checking code has been removed in this file. There are no guarantees on this working! This file should be a little faster than the file in the plugin.
iceman325 (5th October, 2013), Johnny2good (17th June, 2015), tipster69 (15th April, 2013)
@ deadbeef: I've sent you a PM
Cheers- AL
Oops, sorry- I thought I heard a BUMP
Every time i try run autobouquets I get an error and the box resets..
+1.
Thanks alot!
