Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
    Sep 2009
    Default >>>>>>>>>>>>>>>New DAS/Xentry 09/2012 updated<<<<<<<<<<<<<<<
    Setup should work if you have appid 253.
    1. Use guide 2i to install (it has been available for quite some time at http://www.digital-kaos.co.uk/forums...2011-a-226318/ )
    2. Download attached file and read readme inside to get appid 253. Note: you will get new appid only after launching setup. The setup will prompt you to enter key.
  2. The Following 15 Users Say Thank You to zolookas For This Useful Post:
    ACDC (15th April, 2014), amoss54 (24th January, 2014), AOYM (17th August, 2013), dlaskarb (6th April, 2013), dregath (2nd May, 2013), dunnnia (27th March, 2013), lma377 (2nd October, 2013), MS1 (21st July, 2013), Nittte (29th April, 2024), Plutoe (7th January, 2014), rachido_miss2009 (11th April, 2016), tester4 (19th May, 2013), wsc (1st April, 2013), xbccv22 (30th July, 2013)
  3. #2
    DK Veteran wsc's Avatar
    Aug 2009
    GR
    is it possible and App250 with with registry value Compact4?
    Smart car engineer ,
    impactops's Avatar
    Quote Originally Posted by wsc View Post
    I think what zolookas has posted is good for now, it gives an appid of 253 without having to run it in VM
    Regards
    Impactops
  5. The Following User Says Thank You to impactops For This Useful Post:
  6. #4
    Aug 2009
    GR
    yes i know m8 just wonder
    thanks for replaying
  7. #5
    impactops's Avatar
    That is all that's required to complete the install of 9.2012, the App253.rar which he has posted above and NewGuide2i which he updated sometime back.
    This should also work with 7.2012
    Regards
    Impactops
  8. The Following User Says Thank You to impactops For This Useful Post:
  9. #6
    Sep 2009
    yes, it is possible, but changeing only reg value is not enough
  10. The Following User Says Thank You to Visroni For This Useful Post:
  11. #7
    impactops's Avatar
    JC and his crew are to blame for this, he should of never used Compact4 in the registry for PC installation in his procedures if he was not prepared to follow through and make SD think it was an original compact4.All MB are doing now is closing the gaps, gaps that allowed JC cleaning services to exist in the first place.
    Regards
    Impactops
  12. The Following User Says Thank You to impactops For This Useful Post:
  13. #8
    Aug 2011
    Post great things from Z
    Great post from Master Z
    i wonder why u always post a Great things
    when people search for a clue
    it will wipe off the intrigue people also the cleaning service
    Thanks for sharing the Truth in DK
    best regards
  14. The Following User Says Thank You to vspeed For This Useful Post:
  15. #9
    Member skymastor's Avatar
    Nov 2009
    Germany & UK
    Quote Originally Posted by vspeed View Post
    I'm still at a loss to find out what the truth is regarding certain things, but I'm sure I'll pick it up along the way....
    Can someone please confirm that this version (09/2012) only comes on one DVD?
    And so I understand what happens during installation, could someone also please explain why you have to use the AppID 253 patch? What does it do and why is it necessary?
    Thanks..
  16. #10
    Moderator
    PremierD's Avatar
    Jun 2009
    Only 1 disc .. and 253 .. because it works ..
  17. The Following User Says Thank You to PremierD For This Useful Post:
  18. #11
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    can put the steps to make this work?
    step by step for newbies in xentry
    i already have laptop wih fresh windows and with the 4 partitions
    thanks to all
  19. #12
    Sep 2012
    Apollo Beach, Florida
    Good afternoon,
    I would suggest that you go back to the very first post and read what Mr Z has to say about his step by step guide to installing the software. Then have a glass of port wine!!
  20. The Following User Says Thank You to Plutoe For This Useful Post:
  21. #13
    Meat-Head's Avatar
    sorry to intrude, just would like to know if with this setup you can programme a new steering lock on a W204 without internet or the orange key?
    this is a pub quiz question
  22. #14
    Aug 2009
    GR
    Nop you can't m8
    Like every other version you will need this "shits" for coding and programming
  23. The Following User Says Thank You to wsc For This Useful Post:
  24. #15
    Meat-Head's Avatar
    Nop you can't m8
    the shits?
    so if somebody gets all this kit, ready to go, it STILL has to go to Adolf or Herman at the dealer anyway? for a steering lock job.
