maybe this help for you
br
helgra
br
helgra
Sorry for this post ! i think the only way is etl for this mask .. or obd ..
Thanks anyway.
ETL It's not the only Way but is the Best Way.
I use dialprog o diga pro
Inviato dal mio GT-P1000 usando Tapatalk
my instruments:
diga pro,dialprog, rosfar, R270, R260, nyo 2012, upa usb 1.20, x-prog.m, etlweb, nec interface, fgtech galletto 2, galletto 1250, galletto 1080, mpps v12 and v13, kwp2000, race interface,race 2000, ecm titanium etc...
You can read this mask without problems with Ak400 or Carprog
C7-65-D2-3A-D2-3A-D2-3A
How do you read 4j74y with carprog?
Best regards
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
Xprog in secure 4j74y ? Maybe i need upgrade mine
I have read this mask always with carprog original without problems.You can use pdf of HC08 carprog user manual.
martinracing (15th June, 2020)
if you have etl and not have security bytes for 4j47y you can find the security butes if you read it as 3k85 mask
Etl have to use ass for 4j74y, at least for saftware version, 2.7 and 2.8.
this means, even you had sw by reading as 3k85k, the etl still can nor read 4j74y correctly as it does not take the ss.
then, the problem is how do I know the contents read and write as 3k85k is correct?
