Results 1 to 4 of 4
    Nov 2011
    EU
    Default Upa usb, problem
    Hello I have problem with my upa usb.
    When I try to read something I get the following error:
    Reading: 1Errors Found Device 24c16 Range: 0-7FF
    Vdd/Vcc Out of Range
    If I go to connctions, I can read out that Vcc voltage is 1,23 Bad
    What should be wrong?
    Moderator
    PremierD's Avatar
    Jun 2009
    Try suppling UPA with 12v ..
    Nov 2011
    EU
    It works! Thanks man... Fault was in fuse n15.
    Best regards
    Jan 2017
    IN CIRCUIT
    Partner I have same problem in my upa which is fuse 15 to verify if my upa works correctly I could not read eeprom 24c16 much I thought ...
