Results 1 to 9 of 9
    Oct 2012
    Default VU+ UNO New Image Help Needed
    Hi, I'm trying to flash latest VIX image to my UNO, do I need to update or install a bootloader first??? Please keep it simple. Cheers
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by pobreton View Post
    no mate,the latest bootloader is in the image
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
    Oct 2012
    Default Thanks
    Thanks benny/9, It couln't be simpler than that! Cheers
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Dont have a usb stick with any bootloader come within 20 feet of an Uno
    Bricked mine a few weeks back with a duo bootloader
    Freck
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    stick blackhole on it m8, best image for the vu+ boxs by far imo,regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
    Oct 2012
    Default Sound's interesting
    Thanks Andrew, But how easy is it? will it mess up any other settings, FGPA etc.
    Apr 2011
    Default Vix
    Hi pobreton.
    I have a VU+ Uno with the latest
    Openvix image (381).
    It's the best image iv had.
    When you have downloaded
    Vix (3.0. 381) or any other
    3.0 Vix image, open its yellow
    folder it will say (vuplus)
    Now plugin a USB stick into PC,
    right cilck (vuplus) then up to
    (Send To), and send it to your
    USB stick.
    Now Double click on (vuplus) it
    will turn into (uno) right click
    on (Uno) and send that to your USB stick.
    Go to your Uno, turn off at the back, plugin
    to the front USB on your Uno the USB stick.
    Turn Uno on with back switch.
    Uno will say New Update, click on left
    switch on Uno to start Update.
    Once Open vix is installed their is a
    green Icon buton in the info bar.
    If their is a new version of Vix it
    will flash green,
    goto Munu-Setup-Softwae Update
    to upload new version.
    All your setting will also be loaded back in
    including you (CCCam cfg file).
    BF.
    Feb 2009
    it wont mess up your settings, just do a back-up first and if you dont like it you can always go back,regards mdt
    Oct 2012
    Quote Originally Posted by Bbigfoot View Post
    Hi pobreton.
    USB stick.
    will flash green,
    BF.
    Hi BF,
    Thanks, your clear, easy to follow instructions did the trick. I flashed build 381 and then updated to 398. However I lost my cam, cccam Manager was empty, I downloaded CCcam 221 through TS-Panel, it is selected and active but I can still only receive FTA, any tips?
    Pobreton
