Results 1 to 13 of 13
    Oct 2008
    Default USB to 9 pin null modem cable
    Sorry to post a message again, I previously did it on someone elses post.
    Got a USB to 9 pin adapter from flebay, which I have installed with the correct drivers and I can see it in decive manager under Prolific USB to Serial Comm Port. I managed to change it to Com Port 1 and the other communications port is 2.
    When I try to connect to my eurovox ex5000 I click on download, select the com port 1 but the pc and the box just do not want to talk to each other.
    I have only installed the driver for the USB to 9 pin adapter. Do I need to install software.
    Thanks guys.
    Top Poster Ev0151's Avatar
    Jan 2009
    Try it on a normal PC.
    Laptops never seem to have 9 pin serial connections.
    When i had the same problem with the USB to serial DB9 adaptor i just used another pc with the 9 pin serial connector and it connected straight away.
    Oct 2008
    I have tried both my desktop and laptop but no joy!
    satsmo's Avatar
    Jun 2008
    You have to use a null modem cable in conjunction with the USB adapter. Are you using one?
    Oct 2008
    Yes I have a null modem Cable and can sucessfully connect to my Eurovox when I connect directly to my desktop
    satsmo's Avatar
    Jun 2008
    Slightly confused ? Can you connect to your desktop now?
    Oct 2008
    I can connect to my desktop when I do not use the USB to 9 pin connecter via my serial port, so I am connecting with just the null modem Cable.
    I want to be able to use the USB connector so I can use my latop which does not have a 9 pin port so I can update my brothers box when I go to his house.
    satsmo's Avatar
    Jun 2008
    I see. Are you using the correct driver for your OS?
    Oct 2008
    I am assuming that if I can see it in Device manager without a yellow exclamation mark that I have the correct one.
    Will try the other drivers and let you know how I get on.
    Thank for you avice so far.
    satsmo's Avatar
    Jun 2008
    Sounds like the correct driver, but according to your first post:
    You need to have the USB adapter set to any unused port between 1 and 4 for the UFL to be recognised by your serial port. You say you have changed two port settings?
    Oct 2008
    I changed the port setting so that Port 1 would be the usb one for simplicity and the other port 2 which was port 1
    Just thought that when the computer looks for the connection it will look at port 1 first.
    satsmo's Avatar
    Jun 2008
    OK even more confused now The UFL will search between ports 1 and 4 as said. Once you have the adapter set to one of these ports in device manager the box will see it.
  13. #13
    yes ua hve to do t9i rgth away non stop yes and do it 5 pin female to male alpha
