Technomate Loaders - Page 2
Page 2 of 13 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 185
  1. #16
    V.I.P. Member opsmonkey's Avatar
    Nov 2008
    var/etc
    Keys are for specific channels or packages.. just because one channel clears with keys doesnt mean another will..
    Some channels will be Nagra2 which is open and some Nagra3 which isnt and is very unlikely to become open
    Could you also explain how you all get the softkeys so quick and post in an acceptable format that the receivers can understand?
    thats THE $64'000 question and one you will not get an answer for
    Is their a program we can easily use to do it ourselves?
    No.. there used to be an AU (Auto Update) available in firmware but these are mostly gone as channels improve encryption services
    Keys, Cams & Updates are a dying form mate.. Those channels that used Nagra2 and other types of encryption that were hacked have all started to move over to more secure encryption, they were loosing millions of pounds in revenue due to a lack of genuine subscribers..
    Very soon nothing will be open, this has just happened in the USA, Europe will not be far behind..
    I'm afriad to say that if you want to view Pay TV without a subscription it will have to be via a server box like the Dreambox or an IP Box
  2. #17
    Default Thanks
    Couldn't find the loader for the TM3100D anywhere else!
  3. #18
    Nov 2008
    Default technomate 500 loader
    Quote Originally Posted by Devilfish View Post
    1 1000/5000/6000 series
    2 3000 series
    3 7000 series
    All loaders transfer patches, keys, channel lists, logos, tps files through a 9 pin null cable
    hi devilfish,i am new to all this,i have a technomate 500 but i dont know which loader to use. any help would be great. jhaye2x
  4. #19
    Default help patching
    could someone please tell me what i need to load for to patch it via the usb please im a greenhorn here thanks
  5. #20
    Jun 2009
    Quote Originally Posted by khempsmlv View Post
    all help should be in the sticky thread section but if you are stuck you will have to give us your exact model as the patches are for specific boxes.
  6. #21
    Quote Originally Posted by jhaye2x View Post
    You don't use a loader on tm500.
  7. #22
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    Quote Originally Posted by fearona View Post
    You have a image for the box, then using Technomate Control center you send it to the box and it should flash in a few mins.
    Read the Rules here; they apply to EveryOne.
    __________________________________________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 motor powered by UsalS
  8. #23
    HI i have a tm-7755 2va 2ci and am getting an error0 showing The reciver is locked up Can any one tell me what the error0 is and how i can fix it AM A NEWBIE TO ALL THIS
  9. #24
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by burilad View Post
    you need to do a forced download mate give this a try.
    if you have a bad download or your receiver locks up this is how to
    clear the problem, you can only do this procedure with a [null modem cable]
    if your model has a [usb port], this wont work useing a [memory stick]
    first turn the receiver off with the switch on the rear panel of your receiver.
    next connect your null modem cable from your computer 9 pin com port
    to the rs232 port on the receiver, you can now use either the official opperating software from technomate.com or load the latest patch for your model, after loading the software on the v187 loader and you click connect
    when the darkman v1.87 loader asks connect the receiver and turn it on
    go to the receiver and turn it on again with the switch on the rear panel
    turning the receiver on at the rear will force the download and clear the problem caused by any incomplete downloads or faulty patches etc:.
    after the download has fully loaded the box should now boot and work normally and the channels open
    some take the lnb cable from the receiver before doing this download
    if you remove the lnb cable make sure the receiver is turned [off] before
    you [remove or re-connect the lnb cable].
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
  10. #25
    Question Technomate 5400 newbie - what do I need to download
    I'm an absolute newbie, and I've got a Technomate 5400. What would I need to download to have the latest patches? And I've heard I also need a softcam??? Do you think it's possible to get Living2 and some kids channels?
    2 3000 series
    3 7000 series
  11. #26
    Default technomate tm 6900
    hi mate i try everything to download the software to the machine no luck,my be of the vista on my computer?
  12. #27
    Jun 2009
    Quote Originally Posted by bienchen View Post
    If you give us your exact model we can help because you need different patch depending on model.
    also patching will not help if you can only get astra/eurobird @ 28.2 East.
  13. #28
    Quote Originally Posted by dick b View Post
    I am in a similar poition to "bienchen" but with a :
    Model : TM-1000D SUPER
    S/W Version : Darkman 2.11p (Nov 17 2006)
    H/W Version : 1.11
    Boot Version : 2.10 (08:11)
    CH Version : OCT:06
    Please can anyone help with links to what i need to download to bring the box to its maximum viewing potential. It is connected to a motorised dish.
    I have a PC and a 9pin laplink / null modem cable.
    I downloaded Darkman_TMLoader_187 from this brilliant forum. Is it the correct / latest loader for my TM-1000D ?
    What other downloads can I feed into the loader to update the box keys, channels, etc.... ?
    Kind Regards and Thank You
    Naresh
  14. #29
    hi can you tell mi how do i get acsses to the all sat forum i need key for the thor sat thank you
  15. #30
    maca's Avatar
    Feb 2009
    liverpool
    Quote Originally Posted by said2009 View Post
    just wait 20 minutes for the server to update then away you go..
