OpenPLi-2.1-beta-dm800-2012-10-27-By-gjstroom-dOOds-Backup - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 61
  1. #16
    Jul 2012
    I got this image installed, mounted USB as main hdd, contain cross epg, picon folder and movie. The problem now if I open device manager, green crash screen comes " erron12 can not allocate memory". Any ideas.?. May be the picon folder cause problem?..
  2. #17
    DK Veteran billy2's Avatar
    Jul 2008
    some where over there
    just flashed yhis last night and having 2 probs, one is i cant get rid of subtitles have tryed the above and it dont work ???? and 2 how do i format hdd ???
    cheers
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    sometimes life will kick you around , but sooner or later , you realize you`re a warrior , and your stronger than anything life throws your way !!!!!!!!!!!!!!!!!!!!!!
  3. The Following User Says Thank You to billy2 For This Useful Post:
    remzy (27th September, 2014)
  4. #18
    says older or invalid image.
    sod, as it looks great
  5. #19
    Top Poster skydive80's Avatar
    Out The Box
    Hi guys hi have finally changed to this image and im very impressed, everything is working except i can not get permanent timeshift to work and the picons to display....anyone help please
  6. #20
    Oct 2010
    skydive80,create a folder on your usb stick called "picon" and then put picons in there and they will show..Also i believe u have to install plugin permanent time shift for that to work..have you also set all the recording paths in the menu?? By the way i have upped a newer image the other day...
    And... radio,if you get your self ssl84b bootloader and flash that first then flash the image all will be fine..Your bootloader is probably older.. Hope this helps guys
  7. #21
    Out The Box
    Thanks Doods, i have installed permanent timeshift but its not showing, how do i change path to use this
  8. #22
    Member gaelicred's Avatar
    Feb 2013
    Dublin
    Thumbs up
    had b/l 76c flashed to 84b and then flashed this image , had trouble with subs but got rid of em ! epg is great , 1channel is hit n miss , just installed mytube player ... all good so far , thanks!!
  9. #23
    Oct 2010
    Link To Newer Image Guys & girls...
    http://www.digital-kaos.co.uk/forums...backup-320447/
  10. #24
    Feb 2013
    Dublin
    Hi dOOds , image is working great ! would you have or recommend an icefilms plugin that would work with this image ? 1channel is doin ok but the icefilms gives a hd link too ,cheers!!
  11. #25
    Oct 2010
    You can try this icefilms plugin buddy...Extract from the rar file and then ftpthe wholefolder to /usr/lib/enigma2/python/Plugins/Extensions And then reboot box..This version worked ok for me before...You might also like to try this plugin...enigma2-plugin-extensions-tsonlinetv-1.6_1.5_all Which is live streaming on tv shows/channels etc..This you will need to install local extensions by putting it on usb or temp..Hope this helps..Let me know how you get on..
  12. #26
    Feb 2013
    Dublin
    Quote Originally Posted by dOOds View Post
    Great stuff dOOds ! prob won't do anything till the weekend but will let you know !!
  13. #27
    Feb 2013
    Dublin
    Update ! just finished installing the two files , all seems to be running as smooth as.... , excellent stuff mate , cheers!!
  14. #28
    Nov 2011
    Where to download?
  15. #29
    Nov 2011
    Mean, HOW to download?
  16. #30
    Oct 2010
    Quote Originally Posted by midi View Post
    Where to download?
    Copy and paste this in your browser
    http://www.mediafire.com/?hofoprwicup148i
