OpenPLi-2.1-beta-dm800-2012-10-27-By-gjstroom-dOOds-Backup
Page 1 of 5 12345 LastLast
Results 1 to 15 of 61
    Oct 2010
    Default OpenPLi-2.1-beta-dm800-2012-10-27-By-gjstroom-dOOds-Backup
    For DM800 Clones-ssl84b-Lazy mans image-Ready to go
    New image with SIM2 SSL84b and 'tweaked' 20120216 drivers.
    I also included the new OpenPLi 3.0 bootlogo's, they have a nice fresh 'look'.
    It looks like the DM800 doesn't get a OpenPLi 3 update because the lack of cpu power
    Added...
    HDGlass 6.75
    TSPanel 6.6
    dFlash 3.3
    Mgcamd 1.38
    cccam 2.30
    CrossEpg
    Clearmem
    1Channel
    http://www.mediafire.com/file/4a6jl9ui8j5zhzv/OpenPLi-2.1-beta-dm800-2012-10-27-By-gjstroom-dOOds-Backup.rar
  2. The Following 7 Users Say Thank You to dOOds For This Useful Post:
    ernestodee (7th November, 2013), nav007_2000 (15th September, 2016), papahenki (20th May, 2020), robbieangie (11th August, 2014), scottie35 (3rd April, 2013), skingdeven (31st March, 2016)
  3. #2
    Jun 2008
    for some strange i can't get rid of the subtitles and unable to mount usb drive.. any ideas.. also how do i enable mgcamd their is no blue panel on this image
    Quote Originally Posted by |ih4x| View Post
    Hi mate
    Not sure about the usb HDD I only use internal but I think you should be able to mount it via Tspanel.
    For your cams go to your plugins and hit the green button you can then get ALL you need there.
    Regards subtitle I'm not sure unless you mean narration then to turn that off press your audio button and change it to English.
    Oct 2010
    all All cams are installed already...press menu/setup/softcam/ci and there you change your cams...
    For mount usb etc...format to fat32 on ur pc and the image will recognise it automatically....or press menu/TSPanel/tools-1/device manager....Voila..hope this helps
    Jun 2008
    thanks for the info at first flash i was getting lots of glitches..no video on fta but a fresh reflash seems to have solved that problem. nline working better.. just guna play about with skins and try mounting my 32gb usb stick again..
    Top Poster domirudi's Avatar
    europe
    Have anybody tried this image in db 800 HD pvr clone.Is this ok for this type of dreambox(clone?)
    Oct 2010
    what does the title say mate?????
    Jun 2008
    I just got a 500gb internal hdd device manager allows to format to ntfs. But i realised it stiks after awhile nd i hav 2 power off da box. Also cross epg causes freezes the box
    The hdd is good and has 7200 rpm
  10. #9
    Jul 2008
    Just flashed this image, gonna have a play about and see how it handles crossepg and also permanent timeshift with internal hard drive installed.
  11. #10
    Dec 2012
    does the 1channel plugin work on this image.
  12. #11
    Quote Originally Posted by markslyf3 View Post
    Yes it does mate but you will get the odd crash, that's just the way it is!
  13. #12
    Jul 2008
    Question with regards to OpenPLI image. I have a DM800 HD PVR clone box and I have tried some openPLI images but they keep saying its an invalid /old image but it used to have an openPLI image. How do i know which image to use. It had a sim2 bootloader
  14. #13
    Member steve67474's Avatar
    Default Subtitles
    As first poster mentioned. This is a gr8 image but I am stuck with subtitles. I have been through all the menus. There is even a subtitles option in system but all it does is change where its shown etc. How do you turn them off.
    I have had no joy with the Dream elite and GP3 images as they seem to hang on booting. I have tried about 10 images and this one setup great, got epg vlc etc all running in minutes but stuck on this ****ing epg thing. PLEEEESE Help LOL
    Learn how to hold a bear with a mic in your hand Kylie LOL
  15. #14
    Feb 2011
    found off another site
    ok. you press the yellow button for choice of audio and then press yellow again and it will show you the subtitles that are running. press ok on that and will turn off subs.
  16. #15
    Feb 2011
    Quote Originally Posted by paul29 View Post
    Just make sure there are no X's on both lines
