what you doing to night. - Page 117
Page 117 of 200 FirstFirst ... 1767107112113114115116117118119120121122127167 ... LastLast
Results 1,741 to 1,755 of 2987
  1. #1741
    ifred's Avatar
    ON TOPIC:-
    waiting for darkness, the polack who parked so it was VERY hard to get in my
    gate post will find a flat tire to change, theres a no park zone for a reason buffy
    Why not weld gatepost to outside of polack car with note on windscreen "please park outside gatepost next time"
  2. The Following User Says Thank You to ifred For This Useful Post:
    Meat-Head (16th September, 2017)
  3. #1742
    Meat-Head's Avatar
    Great idea but the pollack pished off before could let his tire down.
    ON TOPIC:-
    tonight, hoping fat unemployed friend can help
    me with a problem with one of my nuts, it won't come
    off the main body, tried usual angle grinder key as you do.
    even leaned funny on it and whacked it with a hammer.
    i held my button in and whacked it very hard many times up
    a handy 205 litre oil drum, used some UB40 on it, got the
    angle grinder key again with a bit of steel water pipe, still solid.
    so had no choice but to use 4/1/2" (115mm) grinder instead but
    one sheet one disc, at least 9" (230mm) cut plenty
  4. #1743
    ifred's Avatar
    ON TOPIC:-
    You should of paid the Chinese likey *Hot* parts girl the £5 fee. They know how to get frozen nuts of the main body pretty quick the final cost with after tax cost usually higher!
    If it was the other type of nut a few second blow torch cracks the corrosion- thermal shock ----Meaty your an amateur
  5. The Following User Says Thank You to ifred For This Useful Post:
  6. #1744
    Meat-Head's Avatar
    Could try nuking my nut
    update
    polack across gate again, psssssssst
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    ifred (16th September, 2017)
  8. #1745
    ifred's Avatar
    Why don't you put TV beside gate with sofa, then your Fat unemployed friend could freeze the polak out or even "BIG Daddy Splash" him
  9. The Following User Says Thank You to ifred For This Useful Post:
    Meat-Head (18th September, 2017)
  10. #1746
    Meat-Head's Avatar
    Tonight cant rember what its for, either probation officer or mental health woman
    shifted my stuck nut, needed bigger hammer
  11. #1747
    Meat-Head's Avatar
    IPDATE:- & iShit failure
    Turns out it is chiropractor tonight
    Later will be cutting up metal sheets and yet another go
    as stripping paint, flakes off in the sun, won't shift anywhere else
  12. #1748
    ifred's Avatar
    Acetone will -also safety boots, trousers, even probably imaginary cat good for your nail varnish also but has to be nice smelling acetone for that
  13. The Following User Says Thank You to ifred For This Useful Post:
    Meat-Head (19th September, 2017)
  14. #1749
    Meat-Head's Avatar
    Tonight painting town red if drop paint if not gate red
    then watching this if remember
    https://m.youtube.com/watch?v=upUpVb3cLfk
  15. #1750
    ifred's Avatar
    Off to supermarket (no advertisement here) to buy loads of beans, sausages etc for big B&Q world ends today
    Mysterious planet called Nibiru smashes into Earth
    as Irnbru crashes into earth today!
    Anyone know the exact time so I can fire the BBQ going at the right time. Meaty here's your chance of hot date with HOT parts girl as its "THE END" "LE FIN" "ENDE"
    I will sling garden hammock over the canal for you
    Ifred does best B&Q outside of Meatycity big firework display promised at end what could beat that
  16. The Following User Says Thank You to ifred For This Useful Post:
    Meat-Head (23rd September, 2017)
  17. #1751
    Meat-Head's Avatar
    As normal somebody pressed fast forward on the weekend
    hoping to unbolt some bits of metal but nil poi
  18. #1752
    ifred's Avatar
    Meaty decoded: Read some smut mags in bed on weekend Woke up Monday morning in panic
  19. #1753
    Meat-Head's Avatar
    Tonight ubolting something, unbolting something else, then hiding the evidencee before it gets dark
  20. The Following User Says Thank You to Meat-Head For This Useful Post:
    ifred (25th September, 2017)
  21. #1754
    Meat-Head's Avatar
    UPDATE FOR LAST NIGHT:-
    fell asleep instead
    TONIGHT:-
    went to see a man about mowing a medow, but his wife has put her foot down
    and he is NOT alloud out for a week
  22. #1755
    Meat-Head's Avatar
    Last night:-
    Vic my imganary friend seen a 32" TV dumped in the street, can i grab it for him.
    so grabs said item, no power cord, all scews in, back off, somebody been inside & had psu board off.
    i found the fault, fixed it using regular household items, cleaned case, works great
    so i told Vic it was not repairable, it is now (serisoly) on a stool end of my bath
    as can use as pc monitor and view dk & tweett in the bath
    thanks Vic.
    tonight, needs some supplys,salpetre, charcoal and sulphur,
    got to preservse some meat, do a bbq and cool my pets blood down
