Page 144 of 200 FirstFirst ... 4494134139140141142143144145146147148149154194 ... LastLast
Results 2,146 to 2,160 of 2987
  1. #2146
    Operating system installed succesfully today after 50 errors and missing this and that
    and burned 2 bootable discs to have one working during these days.
    Today spent a lot of hours in bed because it's 15th August
    and work will start on 20th August.
    Even if the garage told me they want to fire me cauze I take so much time,
    especially to change an alternator.
    I told sorry, I didn't work with modern engine that has alternator belt tensioner.
    Plan to fix no start car in 51 weeks.
  2. #2147
    need to find why got 43VAC between washing machine case and the kitchen sink.
    Because the socket where the washing machine is attached is not grounded to earth.
    1) You need to find where is the earth rod in your garden.
    If you have an earth rod in the garden.
    2) Open the wall socket. Is there a wire connected where the earth wire must be?
    a - There's a wire
    b - No wire
    > a- Open all the electric box or wall socket near to the washing machine.
    Could you follow THAT wire?
    > b- Run a wire from the washing machine wall socket to a trusted wall socket that
    is grounded or directly to the earth rod*.
    *It is not intended that MH will use a wire from wall socket that lay to the floor untill it
    reach his handmade earth rod made of welded tesco can/jar
    but everyone know that it is exactly what is going to be his PERMANENT solution.
  3. The Following User Says Thank You to alessioblaupunkt For This Useful Post:
    Meat-Head (16th August, 2018)
  4. #2148
    Meat-Head's Avatar
    Guessing where the earth point through the filter not making contact and water heater failed insulatin
    TONIGHT:-
    if rainng fixing washing machine, if not raining doing some tweaking see if can get temp above 85 deg c by pushing burner in deeper
  5. #2149
    ifred's Avatar
    Buy an insulation test meter burn the kitchen sink and wash machine with 1000V. then when they are both kaput! you know why? otherwise yes 43V is induction induced current through L and N being un-paired common on light circuit where there is what's known as a borrowed neutral and not earthed. Meaty your Chest pain have you got welders flu: http://www.hse.gov.uk/welding/illness.htm
  6. #2150
    Meat-Head's Avatar
    Thanks, never heard of that, not welding not done any 13 months, but will be this weekend
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    ifred (16th August, 2018)
  8. #2151
    Meat-Head's Avatar
    Tonight painting piece of metal and checking weather
  9. #2152
    Meat-Head's Avatar
    Either sleeping or playing with myself and my one remaining large white ball, changing it to color changing
    If not pub with weird friend
  10. #2153
    Meat-Head's Avatar
    Seems last few hours if weekend more productive than the entire weekend.
    got some bits of angle iron cut, set fire to the grass, then also had a. Feeling of intense heat in my spud area
    then noticed a hole in my trousers, letting thousands of sparks in.
    crushed 23 cans of empty beer
  11. #2154
    Meat-Head's Avatar
    So moved the 1981 piece of machinery to one side, drilled 8 M8 holes
    found piece of wood, moved engine crane out t way
  12. #2155
    Meat-Head's Avatar
    Hope hilly iShit hopefully installing lump of metal 3 foot square in a hole tonight
    then welding some bits of metal
  13. #2156
    Aug 2018
    i'm just going to get some chips and watch netflix all night )
  14. #2157
    Meat-Head's Avatar
    Tonight, BIG argument with small piece of metal, and two pop rivets and lost
    now inside sulking
  15. #2158
    Meat-Head's Avatar
    UPDATE:-
    eating 4 ice creams in the rain
    UPDATE, UPDATE:-
    Somebody getting free flat tire, and another one as a bonus
  16. #2159
    Meat-Head's Avatar
    Tonight
    retruving the now straight bent nail in the street, then looking for a car with emergency spare tire fitted
    then welding some angle iron, REALKY looking forward to making welder noises
    as I'll feel more important
    then em weird friend if time
  17. #2160
    Meat-Head's Avatar
    Got rained off last 20 mins last nite
    need to buy new angle grinder
