Looking for a pair of bent pieces of metal, tesco for food
Update to last nite:-
took ok something apart, cleaned gunk out, now broken
TONIGHT:-
weird friend down pub
footing turf
Not sure
sleeping, pub with weird friend or food poising from tesco pizza
Tonight, got pressure washer on my undercarriage and cleared load of klinkers off.
this in turn left the concrete black, so blasted that off.
give up trying to free the flappy thing, seized solid, absolutely solid, the brass fitting has seized to aluminium head
wont shift, with heat or ice stuff.
unwrapped knotted cable.
tomorrow, somebody else's shit
Start with tesco, clear Rtc shelf, then rapid power nap whilst microwave burns said dinner, then burn tongue on said food, then admiring the new pond in back garden
Started with power nap, then took a machine which goes ping apart, then looked for water leak on end of hose pipe, found it, bad factory seal, reseated, pished ever more water in.
went to tesco, got goat and toast, dK, bath and bed
ifred (2nd June, 2018)
If weather man correct, then getting wet playing with myself in t garden with something hard
but I throw the aspestos out
Not feeling great after i broke down having a tug in naybors garden.
At least had fault indicator ping up before hand.
just hope I didn't say any inferior websites or racist comments when rebooted.
Was going out in garden but now raining
#internal fault #internalfault
Trying to decode this one? did you say in code, gave a goat a bath and then took it to bed after setting fire to your local tesco????
Also you played ping pong with a machine that makes seals juggle water hoses?
Why is my life so boring compared to yours.....Is it the polish beer you guzzle?
Meat-Head (2nd June, 2018)
For educational or entertainment purposes domestic microwaves have aluminium two strong magnets and a powerful heavy money worth weighing in transformer WHICH AT 7000,000,000 MV WILL KILL YOU INSTANTLY (but only once)
some polack dumped on in t' street, the foam rubber caught light.
DO NOT BREAK THE PINK BIT OR CUT YOURSELF ON IT, it has cyanide or arsenick inside it.
That is what was going ping.
then I have a car that leaks water, found the leak on the end of the hose pipe.
UPDATE FROM TONIGHT:-
was screwing around with myself and had to stop due to dull pain in middle of my chest.
i did manage to put the battery's on charge, but don't feel well to smear the grease around the board, battery terminals and solar cell
Currantly logging off
Still got tight chest, but still works
TONIGHT:-
hopefully admiring the new solar lights on naybors garden
need to make cat proof as they are good quality lidil ones.
If you upgrade the microwave into a DIY welder and then attach it to the solar light the Cats won't bother it for long, no need of a takeaway more a instant home BBQ
https://m.youtube.com/watch?v=neR_RFTblqg
Yes, replacement lights are going to be mounted on M12 threaded bar with poundland chicken wire around then, no cats knocking then off
TONUGHT
WEIRD friends, terry and Junes, still got this aftermarket pain in chest between my tits
niw been told by 6 people "to go see a doctor for some help, dizzy my heads like a whirlpool" then pass iut
after having a good tug. Been told next time might not reboot, like I care.
