Page 105 of 136 FirstFirst ... 55595100101102103104105106107108109110115 ... LastLast
Results 1,561 to 1,575 of 2026
  1. #1561
    ifred's Avatar
    Jun 2010
    910
    Downloads
    34
    Uploads
    Took a greenhouse apart yesterday now have big mecano kit. To day will rebuild it Question is what will it turn out as?
    Can MHM since they are experts at dismantling and ishiting things! Give advice on what I will end up with?
    I don't need a bike though!
  2. #1562
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    Melt down the ally into ingots
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    ifred (19th April, 2017)
  4. #1563
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    Update:-m
    fell asleep, woke up, read some "Viz" "Jizz" and car mags
    went for a bath
  5. #1564
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    Tonight matthew, im going to be taking some seats and carpets out a car to weld it.
    weird friend meant to be coming round - assuming he unconcious
    and taking away something shiney, that some bar-stuart is missing.
    i thiught they was aluminum, turns out their sodding stainless, lucky
    that he has a stainless steel fetish, cos he is weird
    No beer in them anyway
  6. #1565
    May 2010
    103
    Downloads
    Uploads
    Answer to post #1557
    I didn't phone call the "job offering man" cause die golf3 did only crank but no start.
    Looks like no fuel out of injector but the resistance value is ok and in tank pump is pumping fuel...
    Happened 3 times since january.
    first time the car was sitting since 5 hours.
    second time the car was sitting since 10 hours.
    third time the car was sitting since 5 hours.
    Also very hard to see if fuel is coming out, barely visible at idle.
    And car runs good.
    Have to call again the "job offering man" and expose my excuse cause of die golf3 fault
    (and might happen again and again)
  7. #1566
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    UPDATE:-
    weird friend, came round, decided too small for BBQ
    Took something i was saving and ~~~~ed off.
    took seats and carpets out, found live maggot!
    then poked no end of holes in this thing, MASSIVE
    MASSIVE amounts of welding.
  8. #1567
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    Tonight, cutting out more rotten metal, only done one pass with 9" grinder
    the rest came away with bare hands and screwdriver, pry bar, chisel or punch.
    talk about air conditioned! As for the carpet, temped to take to
    ADVERTISEMENT:-
    Meaty Clean Laundrette, anything and everything washed
  9. #1568
    ifred's Avatar
    Jun 2010
    910
    Downloads
    34
    Uploads
    Meaty re-purpose the motor to new use :- vegetable grater
    -On Topic-
    now going to smelt aluminium ingots into greenhouse section and built greenhouse out of them!
    Requestioned microwave from Wifi as smelter hope she doesn't find out
  10. The Following User Says Thank You to ifred For This Useful Post:
    Meat-Head (21st April, 2017)
  11. #1569
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    Holes TOOOO BIG for vegefrator, could sell to fred flintstone
  12. The Following User Says Thank You to Meat-Head For This Useful Post:
    ifred (21st April, 2017)
  13. #1570
    ifred's Avatar
    Jun 2010
    910
    Downloads
    34
    Uploads
    Use for very big veg
  14. The Following User Says Thank You to ifred For This Useful Post:
  15. #1571
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    UPDATE:-
    Instead of making grinding noises, started making my temporary permeant
    powersupply, so got piece of tree with a breakerbox and rcd connected, of course
    used Stannah bolts, then using LONG lentgh of stannah cable so got 3 double sockets
    and BS4343 blue 16 amp trailing socket onit.
    then the other side two double sockets screwed to some more bit of tree
    the stannah cable ties a bit weak so used the ones nicked from work.
    vic was meant to come over, but he ended up being called into work
  16. #1572
    GastonJ's Avatar
    Dec 2009
    834
    Downloads
    28
    Uploads
    6
    I heard that woodn't work anyway, you're barking mad
  17. #1573
    ifred's Avatar
    Jun 2010
    910
    Downloads
    34
    Uploads
    Shhhh! Gas tell him that he might stand for parliament oust Arnold Rimmer
    Not sure which is the worst option?
    -On Topic -
    Plan to do sweet FU today
  18. #1574
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    Quote Originally Posted by GastonJ View Post
    Will try and upload photo later.
    TONIGHT hoping
    to use my temporay perment power supply to use up the pile of 4" grinding
    discs, yes 4" got one 4" grinder left, had 2 killed one.
  19. #1575
    Meat-Head's Avatar
    6,658
    Downloads
    Uploads
    Tonight, if raining inside playing with myself & 9" grinder
    if no rain playing with myself outside.
    got to cut some stolen angle iron up, to get it out from shelving.
    was unable to move it when put shelves up. Vic imaganary friend, was called
    into work at the time
