please give me your help :s
hello all,
I had seen several thread's "immo off" for this ecu type (DCU3R)
but I don't understand were is the pin 20 and how remove the immo for this ecu,
could you please expand me where is the element's for remove the immo
my car it's a m?gane 1,9 dti 1999
the ecu is Lucas DCU3R, and my eeprom it's ATMEL 25080
thank you verry much for your help
regards
For this ecu, no need cut or remouve anything.
You just need WP eeprom when you program it.
hello circuit,
what do you mean by "wp" ?
regards
hi,
that is my original file of my eeprom
thanks in advance if you can remove the immo without emulator,
regards
helo aflou thanks for your message,
anyone can help me with my file ?
thnaks
try to raise it, if you reboot, you need to encode injection
Sorry for my English.
GG 5268481
We are here to help each other unselfishly
Hello doberman95,
when you writes your file with UPA it is necessary to mark write protect as your file is protected in writing and the code does not reregister in the ?prom
Post your file in .rar please.
You sure it is DTI and no D.
Normaly this ecu is put on RENAULT D.
hello barti I will test it tomorrow, thanks
hello guys,
I'm sorry but what is it UPA ?
thanks in advance
regards
hello alfabit,
do you have the good file ?
regards
ithink this ecu in 1.9d not in dti dcur3 becose in dti there is ME5 AND NEW BOSCH 0281010442 AND U NOT NEED TO CUT ANY THINK JUST DO IMMO OFF WITH IMMODECODING AND ALL WILL BE FINE THE CUT IMMO LINE SOLUTION IS IN ME5 ECU BOSH 1.9DTI THERE U MUST DO 7+8 PINS SHORTED AND ESOLATE 7 PIN I HOPE I HELP U WITH THIS EXPLANATION THANKS
ok tisser, tomorrow I will go at my friend test the ecu and look the engine type,
I think your reason it's better to give the good engine type
thanks in advance and I will keep you posted
regards
