Vix EPG causing system crash
Results 1 to 8 of 8
    Aug 2012
    Default Vix EPG causing system crash
    have installed the new VIX 3.0 Image on my Vu Duo ? Looks Great and very practical. My only Gripe is when I go into the Settings > Cross EPG > and try to go down to open TV the system crashes, restart it and go in again ? Same thing. Can anyone make any recommendation as to how to get around this? The EPG Panel is coming up but nothing on it,
    Sep 2010
    please submit any and all crash logs pertaining to these incidents either directly to us via the inbuilt logs manager in the image or if possible upload them to our forum.
    Although i cant say that i have had any such problems with any of my 5 receivers all of which use the latest ViX 3.0 images and CrossEPG / OpenTV.
    V.I.P. Member dell_xps's Avatar
    Where do you have it saving to ? if internal flash change it to hard drive !!
    Aug 2012
    Hi, I have them saving to the installed hard drive, crashes everytime I go into the same settings,
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Hi there it looks and sounds like you have'nt set it up properly so I would check the hard drive is mounted and path set up as well as epg path. If these are ok you would be better reflashing from start as the image may be corrupted. hth
    Aug 2012
    Looking like its the corrupt theory, everything is mounted and pathed etc...
    Jun 2017
    hi there im only seem to be getting epg for free view channel and not anything else. Any one got any solutions for this ive tried deleteing the epg and un installing cross epg downloader and re installing everything but still getting same fault...... any help be apprecated
    nbtechnic's Avatar
    Jan 2016
    Did you solve the problem or not?
