Results 1 to 7 of 7
    Nov 2012
    Default Openbox x3 Dead...
    Hi guys I wonder if you can help me my open box x3 arrived yesterday installed fine scanned 2 satellites was all working perfect went to scan a third satellite it got to 100% then froze, I turned the power off then back on again now all I get on my open box x3 display is a dull number 8. can you guys help me?
    May 2012
    Quote Originally Posted by geordiemax View Post
    Here you go. Try the attached Upgrade programme.
    Nov 2012
    Do I just connect it all and run EromUpgrade i keep reading about a batch file but I don't know what that does or how to use it?
    May 2012
    Just connect it up and enter the abs file that in the file uploaded. Tick include bootloader.
    Box powered off
    Start the loader
    switch box on
    May need a few attempts.
    If your using a laptop with a USB to Serial adaptor you need to select the correct port.
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    that file is just the loader
    you will still need the proper firmware to load.
    I don't think it works with usb adapters.
    The batch file just made the proper eromclient.abs file
    for a version that had support for different models.
    That zip already has the proper file.
    Nov 2012
    Quote Originally Posted by slugworth View Post
    OK thanks, I have ordered some parts will let you know how i get on
    Mar 2013
    hi have u solve the problem??? got same issue, looking 4 some ideas
