You can try this
You can try this
alladdin205 (24th November, 2013)
a.lot
Can someone tell my how to do hard reset for CDP+ STM32F205ZGT6?
ok perfect found
Hope this works, thanks!
Having problem with delphi not recognizing my cdp, hopefully can be solved. Tried changing SN, port setting, and now I try with the tool.exe to see if anything new comes along. I have no clue what I'm doing but I'll go with the flow..
Hello all, I have same problem.
I have original Autocom CDP 2014.2 with 30250 VCI.
I installed 2013.2 and also tried with 2014.2 - Device is unknown in hardware setup (Inside of software under Hardware setup).
Drivers are correctly installed, COM (VCP) port is visible.
I tried also to connect to car but same thing.
please, m I missing something or what? First time using this device, really don't know if there is some procedure to work with cracked software/serial - etc.
I tried with 10251 and also with 30250 - same situation.
I activated software with 30250 serial.
My hardware ID for FTDI is: FTDIBUS\COMPORT&VID_0403&PID_D6DEDo I have to flash device to work or what?
Hi.
This message is displayed if the interface is not connected to the car.
In addition, you need to install drivers twice:
1) COM PORT (your com port 3)
and
2) Universal serial bus controllers.
Maybe you did not install these second drivers.
I am sorry if you already answered on my question but I am newbie using Delphi autocom (SN 100251 rev1), and before first use, I already have a problem.
I have software 2016 and after first use i activated software and i cannot go further because it said that I need to update driver. In settings, I searched for the device. It was on COM9 and i press UPDATE button.
I dont know for sure but I think that connector accidentally loosened and the update was interrupted.
After that, when i connect device to OBD connector there is no light on the box, and after I connect it to PC I got two red lights. Software do not see VCI anymore but PC see it in device manager.
I read this topic and find many solutions, but i do not know which is for my problem, because there are many hardware and software versions
Best regards
update:
i solved problem. even though the program could not detect VCI i pressed UPDATE and it finished this time without any problems.
