Page 6 of 6 FirstFirst 123456
Results 76 to 85 of 85
Thread: Autocom problem
  1. #76
    Jul 2009
    Can somebody help me with a dump for the attiny 45 from autocom?
  2. #77
    autocargo's Avatar
    You can try this
  3. The Following User Says Thank You to autocargo For This Useful Post:
    alladdin205 (24th November, 2013)
  4. #78
    Jul 2009
    a.lot
  5. #79
    Apr 2016
    Can someone tell my how to do hard reset for CDP+ STM32F205ZGT6?
  6. #80
    Dec 2010
    ok perfect found
  7. #81
    Jul 2016
    Hope this works, thanks!
  8. #82
    Aug 2016
    Having problem with delphi not recognizing my cdp, hopefully can be solved. Tried changing SN, port setting, and now I try with the tool.exe to see if anything new comes along. I have no clue what I'm doing but I'll go with the flow..
  9. #83
    Jun 2010
    Hello all, I have same problem.
    I have original Autocom CDP 2014.2 with 30250 VCI.
    I installed 2013.2 and also tried with 2014.2 - Device is unknown in hardware setup (Inside of software under Hardware setup).
    Drivers are correctly installed, COM (VCP) port is visible.
    I tried also to connect to car but same thing.
    please, m I missing something or what? First time using this device, really don't know if there is some procedure to work with cracked software/serial - etc.
    I tried with 10251 and also with 30250 - same situation.
    I activated software with 30250 serial.
    My hardware ID for FTDI is: FTDIBUS\COMPORT&VID_0403&PID_D6DEDo I have to flash device to work or what?
  10. #84
    Dec 2014
    PL
    Hi.
    This message is displayed if the interface is not connected to the car.
    In addition, you need to install drivers twice:
    1) COM PORT (your com port 3)
    and
    2) Universal serial bus controllers.
    Maybe you did not install these second drivers.
  11. #85
    Jan 2019
    I am sorry if you already answered on my question but I am newbie using Delphi autocom (SN 100251 rev1), and before first use, I already have a problem.
    I have software 2016 and after first use i activated software and i cannot go further because it said that I need to update driver. In settings, I searched for the device. It was on COM9 and i press UPDATE button.
    I dont know for sure but I think that connector accidentally loosened and the update was interrupted.
    After that, when i connect device to OBD connector there is no light on the box, and after I connect it to PC I got two red lights. Software do not see VCI anymore but PC see it in device manager.
    I read this topic and find many solutions, but i do not know which is for my problem, because there are many hardware and software versions
    Best regards
    update:
    i solved problem. even though the program could not detect VCI i pressed UPDATE and it finished this time without any problems.
