Usb or bluetooth????
If Usb,appears in driver manager?
It is better to arrive 10 minutes early, than to be bored all the way.
sounds like u need to change the serial number http://www.digital-kaos.co.uk/forums...n-here-303232/
I only test with usb but i shall test with bluetooth, i report later thanks
if its not working with usb u have less chance with Bluetooth
I installed 2012R2 Autocom CARS and TRUCKS on the same PC
same serial 20418
Change serial with "autocomCPD tool" but no change
Trucks 39,071, and 30,250 cars
also error
"failed to load function FT_Reload"
Best Regards
If USB not work, maybe your FTDI is broken.
If FTDI is broken, need to exchange it with a new one.
that is FDTI?
What solution do you have?
Best regards
Hello, I have a problem with autocom 2012.2, The test is Ok, but not update Firmware.
What happens?
Thank?s, Regards
are you sure your unit is 100251 and is it connected to a car or 12v
is it the first time u have used the unit ?
dissasembly you device 4 screws
separaste two mother boards
relased 5 min assembly you autocom
autocom now its ready for new firmware
yes all devices whit 5 numbers serial can update
need change serial number whit tool autocom
new device whit 6 numbers can update this no are in black listed 1xx2x1
