I googled Nibiru and found this:
Nibiru is a large planet on an elliptical orbit that crosses the orbit of our planets.
- Like that of great comments that keep coming back over a very long span of time, so does Nibiru.
- Nibiru and it's implications are a part of historical records, and folklore in countless civilizations, worldwide.
- Records seem to indicate that Nibiru comes through our inner solar system about every thirty-six hundred years.
- Because of Nibiru's massive size, it's strong gravitational pull will soon be effecting the Earth in a very big way.
- Effects will range from horrific Earth quakes, super volcanic activity, and sustained 200+ MPH winds world-wide.
- At Nibiru's closest passage to Earth, a quick pole shift will take place, causing the oceans to rush over the continents.
- In the after math, volcanic ash will encompass the globe, thrusting the world into a prolonged winter.
- Until enough ash settles, it's estimated that crops will fail world-wide for at least two growing seasons.
- Those who did not prepare will either die from severe weather changes, quakes, flood, fire or starvation.
- Those who managed to live, will be faced with the aftermath of just trying to survive for the first 24 months.
- All that we once relied on such as utilities, medical, financial, oil, housing, police, etc. will mostly be destroyed.
- Recovery time will be measured in hundreds of years; potentially thousands.
This "potential" pending event is so big, that there is no way that such a secret can be kept much longer if in fact it turns out to be true after all.
Trouble is, by the time we learn all about this through normal channels, you and most others will be out of time to properly prepare. Gathering food for long term storage and building supplies will be next to impossible to acquire easily, do to the onset of global pandemonium, hording of food, and the introduction of international martial law that would follow. That is... if Nibiru is real after all.
Building materials, let alone heavy construction equipment will be next to impossible to obtain.
The old methods of survival will not work in this case, as there are elements to this "possible" coming global change that you must factor in when looking to find the right shelter. Factors that will be to late to adjust for, should things start to go down hill.
Be Prepared For 2012 - Nibiru Explained - Video
