Results 1 to 9 of 9
    DK Veteran RedSpider's Avatar
    Feb 2009
    F**k Off, You Stalker!!!
    Default 12 Things You Should Know About Scalar Weapons
    1. A POSSIBLE SCALAR WAR SCENARIO
    2. HOW WERE SCALAR WAVES DISCOVERED?
    3. A CLOSER LOOK AT SCALAR WAVE-FORMS
    4. HOW DO SCALAR WEAPONS WORK?
    5. WHAT CAN SCALAR WEAPONS DO?
    6. SCALAR BEAMS AGAINST INDIVIDUALS
    7. SCALAR MIND CONTROL
    8. AMERICA'S 'NO CONTACT' MASS MIND CONTROLLING NETWORK
    9. INDUCING DISEASES WITH SCALAR WAVES
    10. TESLA'S TECHNOLOGY WAS SECRETLY CONTINUED BY RUSSIA AND THE NAZIS
    11. IS THERE A SECRET WAR GOING IN THE SKIES?
    12. WHO ELSE IS CONTINUING TESLA'S SCALAR TECHNOLOGY?
    The following seems like science fiction, but scalar beam weapons were invented in 1904 by a American immigrant genius called Nicola Tesla (1856 or 57 -1943) from Yugoslavia. Since he died in 1943, many nations have secretly developed his beam weapons which now further refined are so powerful that just by satellite one can: make a nuclear like destruction; earthquake; hurricane; tidal wave; cause instant freezing - killing every living thing instantly over many miles; cause intense heat like a burning fireball over a wide area; induce hypnotic mind control over a whole population; or even read anyone on the planet's mind by remote; affect anybody's REM dream sleep by sending in subliminal pictures to the visual cortex; cause hallucinagon drug like effects or the symptoms of chemical or biological poisoning; make a disease epidemic by imprinting the disease 'signature' right into the cellular structure; paralyze and or/kill everyone instantaneously in a 50 mile radius and lastly remove something right out of its place in time and space faster than the speed of light, without any detectable warning by crossing 2 or more beams with each other and any target can be aimed at even right through to the opposite side of the earth. If either of the major scalar weapon armed countries e.g. U.S. or Russia were to fire a nuclear missile to attack each other this may possibly not even reach the target, because the missile could be destroyed with scalar technology before it even left its place or origin. The knowledge via radio waves that it was about to be fired could be eavesdropped and the target could be destroyed in the bunker, fired at from space by satellite.
    Alternatively invisible moving barriers and globes made of plasma (produced by crossed scalar beams) could destroy any nuclear missile easily while it moves towards the target and failing all these, it could be destroyed by entering the target's territory by passing through a Tesla shield which would explode anything entering its airspace. To begin with, defense using scalar technology could intercept it before it even landed. Secret eavesdropping of radio communications tapping into ordinary military radio contact using undetectable 'scalar wave carriers' hacking in may have heard military personnel say it was about to be fired. The missile may be destroyed from above the site, using satellites equipped with scalar or particle beam weapons or a cloaked UFO (American or Russian made anti-gravity disk originally made by back engineering crashed alien saucers) or aircraft using scalar or particle beams which could invisibly (and undetectably with standard equipment) cause the target to malfunction and drop down. By using a scalar wave (radar like) 'interference grid', which covers both country's entire military activities in the air, underground or undersea, scalar transmitters send waves over large areas at 90 deg angles to each other. These waves follow the earth-ionospheric wave guide and curve around the planet. It is called an 'interference grid' because all solid moving objects show up as a spot of light moving through marked grid squares on an operator's video screen. Scalar waves are a higher form of radar waves, but they go one step further by passing through anything solid too and are able to detect and be able to be made into a focused beam to target anything through the earth or sea as well.
    A scalar beam can be sent from a transmitter to the target, coupled with another sent from another transmitter and as they cross an explosion can be made. This interference grid method could enable scalar beams to explode the missile before launch, as well as en route with knowing the right coordinates. If the target does manage to launch, what are known as Tesla globes or Tesla hemispheric shields can be sent to envelop a missile or aircraft. These are made of luminous plasma which emanates physically from crossed scalar beams and can be created any size, even over 100 miles across. Initially detected and tracked as it moves on the scalar interference grid, a continuous EMP (electromagnetic pulse) Tesla plasma globe could kill the electronics of the target. More intensely hot Tesla 'fireball' globes could vaporize the missile. Tesla globes could also activate a missile's nuclear warhead en route by creating a violent low order nuclear explosion. Various parts of the flying debris can be subjected to smaller more intense Tesla globes where the energy density to destroy is more powerful than the larger globe first encountered. This can be done in pulse mode with any remaining debris given maximum continuous heating to vaporize metals and materials. If anything still rains down on Russia or America, either could have already made a Tesla shield over the targeted area to block it from entering the airspace.
    Scalar wavelengths are finer than gamma rays or X rays and only one hundred millionth of a square centimeter in width. They belong to the subtle gravitational field and are also known as gravitic waves. Uniquely, they flow in multiple directions at right angles off electromagnetic waves, as an untapped energy source called 'potentials'. Potentials are particles which are unorganized in hyperspace - pure etheric energy not manifest in the physical world. In comparison, electromagnetic waves (measured by so many hertz or pulses per second, which we are familiar with e.g. radio waves) exist normally in the physical world, but can only be measured up to levels determined by the sensitivity of the equipment being used as to how many cycles per second they operate.
    Scalar waves were originally detected by a Scottish mathematical genius called James Clerk Maxwell (1831-1879) He linked electricity and magnetism and laid the foundation for modern physics, but unfortunately the very fine scalar waves (which he included in his research) were deliberately left out of his work by the 3 men, including Heinrich Hertz, who laid down the laws taught for physics as a discipline at colleges. They dismissed Maxwell's scalar waves or potentials as "mystical" because they were physically unmanifest and only existed in the "ethers" and so were determined to be too ineffectual for further study. These enigmatic (but more powerful than even microwaves when harnessed and concentrated into a beam) scalar waves may have been forgotten except that Nicola Tesla accidentally rediscovered them. He'd originally worked with Thomas Edison who discovered direct current, but Tesla discovered alternating current. The two men disagreed and eventually parted ways and Tesla later experimented using the research of the German Heinrich Hertz, who was proving the existence of electromagnetic waves. Tesla found, while experimenting with violently abrupt direct current electrical charges, that a new form of energy (scalar) came through.
    By 1904, Tesla had developed transmitters to harness scalar energy from one transmitter to another, undetectably bypassing time and space. He could just materialize it from one place to another through hyperspace, without the use of wires, it was just sucked right out of the space-time/vacuum and into a transmitter and into a beam which could be targeted to another transmitter. Unfortunately he got no financial support for replacing electricity, which used wires and therefore earned money, and to this day, this is the reason why scalar energy is still not acknowledged in mainstream physics. Tesla, even though he discovered more for mankind in science than many others, is still not credited in science books for his discovery of scalar waves, a source of "free-energy" obtainable as a limitless source of power that costs nothing. Other inventors have sporadically rediscovered "free-energy" but have come to harm or have been silenced by the sum of millions of dollars hush money, a small sum compared to the sale of electricity, oil, gas and a myriad of other energy producers which would then be rendered worthless. Money hungry big business has harshly crushed any opposition to their own riches, generated by multiple obsolete earth polluting fossil fuels.
    These finer scalar wave-forms also have been discovered periodically by other mathematicians, who have been able to calculate new equations especially in harmonics (used in hyperdimensional physics) connecting the wavelengths of matter, gravity and light to each other and how all these lock in and create our expression of time (as it manifests in space) - which has been now discovered to be untapped 'potential' energy flowing in hyperspace. Time flows like a wave-form river in hyperspace in a grid pattern. This consists of interlocking great circles which circle the poles and include a lattice grid of lines that are 30 nautical miles or 55.5 km apart. When scalar beams charge through hyperspace these 'rivers of time' get blocked and redirected temporarily. There is a covert plan underfoot to change the way time is expressed on this planet altogether using hyperdimensional physics and Tesla technology, by splicing earth back onto a now defunct Atlantean timeline in which Lucifer hadn't fallen from grace. (see my other work on this in the books The Universal Seduction Vols 2 and 3 at the end of this article)
    Our present 'reality' is expressed in the way time runs around the corridors in hyperspace by the pattern it takes. Other 'timelines' exist in a different kind of grid pattern, creating alternative versions of our 'present'. Multiple versions of reality (or for example 2 April 2004) can be manipulated given the right technology, and people can enter into parallel universes do all sorts of things and then enter back into this one. One needs a Tesla Zero Time Reference Generator, which can lodge a specific reality into the time at the center of the universe, in which it stays still, acting like an anchor. Both America and the UK govt are able to manipulate and enter into different realities.
    The various dimensions each comprise a complex pattern of interlocking wave-forms. Matter has been found to be only one wave of a pulse comprising a positive cycle, while the negative cycle manifests as 'anti-matter'. The 'matter' pulse brings something 'into' physical visibility, then it disappears momentarily and returns. But the pulses are so rapid we don't see something as unmanifest while temporarily dematerializing. Physical time is only measured by the visibility of something's aging process, or in other words its passage through a journey starting at one measured time-reference point to another. Different wave-forms only appear to us to be solid because we are comprised of the same matter. If the frequencies governing the time between a matter pulse and an anti-matter pulse are shortened or lengthened with technology, time will go faster or slower in the surrounding space or what it effects. Therefore scalar waves belong to space-time in which anti-matter or hyperspace exists. Time can be altered by harnessed and directed scalar waves (including magnets which give off scalar waves which bend time) because they disrupt the pulse of matter and anti-matter and therefore the rate at which something normally passes through time with its usual smoothness. An experiment with scalar waves in USA once caused all the clocks and watches in the test neighborhood to go berserk for 4 days, until the flow of time resettled back to its normal flow and they returned as before. This was noted by Frank Golden.
    Scalar 'potentials' can be created artificially and when focused into a weapon, can do major damage to an object's location in space-time. That which determines the object's natural pulse of matter and anti-matter cycle can become stressed when targeted by scalar waves made of artificial potentials, because they are almost always absorbed by the nucleus of an atom, not the electrons in orbit. Hyperspace can become warped temporarily, although space-time naturally curves around natural vortexes the earth has which form 'chakras' to absorb and release universal energies. These are opened and closed in natural cycles according to the positions of the sun and moon in relation to earth. Because scalar waves are finer than gamma waves they can pass through any physical substance undetected. However the damage inflicted can be so powerful that they can dislodge an object right out of time and space and cause it to temporarily disappear away from its normal movement in time. All objects move in time, and they will also move in space if a physical external force activates the object's own natural internal scalar waves to point in the direction it is sent to causing it to move from A to B depending on how much force is used. Or they are trapped motionless in space by the internal scalar energy within swirling around interlocking into a deadlock, (making it appear still) however the object still moves in time. A beam of scalar energy can cause the timeframe the object resides in to get warped, making it disappear into another reality.
    Particles which are unorganized in hyperspace (potentials) can be harnessed into recreating multiple frequencies of scalar waves and these can now be manufactured artificially and can include frequencies between infrared and ultraviolet. If a transmitter is at a higher reference 'potential' than the interference zone of 2 crossed scalar beams, energy emerges into the plasma 'bottle' which materializes physically and this is called 'exothermic' mode. This can cause explosions and can be 'nuclear like' if set at a high frequency. Even though no electromagnetic energy has flown through space between the transmitters and the target, and because it has bypassed physical space, the energy can suddenly appear faster than the speed of light and destroy something without warning. It is only as a locked in artificial potential that is a directed 'river of force' in hyperspace and it is entirely undetectable with conventional scientific equipment, which is where the danger lies. Nobody can ever know what the enemy is planning or who their enemies are and because it never gets any press normal military personnel without this knowledge would never know what hit them, especially if it is scalar mind control. To extract energy back to the transmitters from the energy bottle of 2 crossed scalar beams the potential must be set at a lower mode and this is called 'endothermic' mode and as energy is extracted out of the 'bottle' area, a freezing will occur, possibly causing a thunderous sound.
    When 2 transmitters send timed pulses, which meet, an explosion will occur which either produces energy or extracts it. If 2 crossed beams are in 'continuous' mode the energy between beams is continuous and Tesla globes and hemispheres can be made which act as a continuous shield to either destroy incoming weapons and aircraft entering it. If multiple frequencies are transmitted on the beams, at the intersection a 3 dimensional globe appears. This can be manipulated to have very high infolded energy with any desired light emission, shape, color or intensity. It can even cause metal to soften or melt. This 'bottle' of energy can be detonated inside the earth to create an earthquake or into a building to make a 'nuclear like' explosion. This 'bottle' can be moved anywhere on the planet or through it and made any size.
    The Russians in 1985 once threatened the earth itself by activating their scalar weapons with multiple scalar transmitters turned on at once, endangering the survival of the entire planet. According to nuclear physicist Bearden, they conducted a massive, 'full up' scalar weapon systems and communications strategic exercise. During this sudden exercise American Frank Golden discovered the Russians activated 27 gigantic 'power taps', established by resonating the earth electrogravitationally on 54 powerful scalar frequencies (27 pairs where the two are separated from each other by 12 kHz.) transmitted into the earth and they utilized this to stimulate the earth into forced electrogravitational resonance on all 54 frequencies. Each of the 27 power taps extracted enormous energy from the molten core of the earth itself, and turning it into ordinary electrical power. Each giant tap is capable of powering 4 to 6 of the largest scalar EM howitzers possessed by Russia. Bearden writes: "Apparently over 100 giant scalar EM weapons were activated and a large number of command and control transmissions and it lasted several days. By alternating the potentials and loads of each of the two paired transmitters, electrical energy in enormous amounts can be extracted from the earth itself, fed by the 'giant cathode' that is the earth's molten core. Scalar EM command and control systems, including high data rate communications with underwater submarines, were also activated on a massive scale. The exercise went on for several days, as power taps were switched in and out, and command and control systems went up and down. Bearden claims not one American intelligence lab, or scientist detected this as they didn't have a detector for scalar EM radiation, and that not one officially believes that the exercise ever happened." However, it was monitored on an advanced, proprietary detection system by Frank Golden for several days and by Bearden for several hours.
    This exercise proved Brezhnev's 1972 statement that by 1985 the Soviets would be prepared to do as they wish, anywhere in the world. The Soviets are using unknown attributes of matter, phenomena and laws of nature by research covering the equivalent of 7-8 U.S. atom bomb projects back to back already. However both America and Russia are doing through the earth scalar beam transmissions and ever since then earth's internal dynamo has been affected. It suddenly experienced a sudden unexpected slowdown in rotation 1984. It has become like an unbalanced washing machine, wobbling as it spins. Scalar waves pass naturally between the center of the earth and the sun, and this coupled with multiple annual nuclear tests (which have been proven to disturb the ionosphere and magnetic field) the balance of the earth with the moon, may even cause the earth to flip, if the naturally produced scalar waves are diverted onto another course, which are keeping the earth spinning harmoniously.
    A Tesla shield protecting a military target could be made of three or more concentric shields, that would produce multiple electromagnetic pulse energy and severe heating of anything which enters it. These concentric Tesla shields can also clean up and sterilize any gamma radiation resulting from an explosion of a nuclear warhead. Nicola Tesla even in the 1920s could create a protective 3 dimensional 'shield' or 'dome' formed by 2 or more transmitters sending widened scalar beams linked together over a target in a hemisphere shape. Instead of causing the target to explode which narrow more intense crossed beams would, a wider more encompassing beam could form a large plasma shell outside something to be protected. This acted like an electrifying force field shaped like a dome, which could cause anything which entered it to have its technology dudded, (inoperative) make incoming aircraft pilots die by destroying their nervous system and/or make an incoming missile, aircraft or tank blow up.
    Multiple layers could be nested made of different kinds of plasmas which would ensure nothing could penetrate a protected target's groundspace or airspace. The Russians can make a Tesla shield up to 200 miles wide. These large luminous plasma shields have been witnessed by sailors over the oceans from time to time, as various nations test their scalar weapons in secret. Tesla, as early as the 1920s created globes or bullets of plasma with crossed scalar beams sucking the energy out of the air space in a 'cold explosion' causing it to freeze, or sending extreme heat into it to burn as a very powerful laser beam. These powerful beams can also travel right through the earth and create an earthquake at the antipodes of the earth and Tesla also experimented doing this. Hyperspace flux energy (potentials) flows as waves in a sea of intense power in the next dimension unharnessed, however when energy is manufactured artificially it can be made into different modes e.g pulse mode, energy extraction mode or explosion mode. If 2 timed pulses meet, an explosion extraction makes a sharp cooling and all heated energy is extracted out of the air back to the transmitter. This can make everything and everyone frozen. It preserves machines and buildings but not people. If a burning energy is sent the target has a nuclear like 'detonation' because energy emerges to a target destroying the nucleus of the atoms. Multiple scalar wave modes and frequencies can also be blended together into one beam as well.
    Tesla globes can be manipulated to be small or large in manifold kinds of energy frequencies and directed to a target by 2 or more far away scalar transmitters. Many intense frequency small globes can be directed towards multiple incoming targets, like cannonballs causing major explosions. Alternatively a larger less intense globe sent can cause the electrics to dud in a plane, helicopter or missile causing it to malfunction and crash land. This technology has been used many times to crash planes or helicopters by using a portable scalar bazooka carried by a hidden terrorist or soldier. The Vietnamese and Soviets used this technology in the Vietnam war against American aircraft. Many planes crashes with inexplicable causes can be traced to this. These Russian made portable bazookas were also used by the Serbs against American helicopters during the Bosnian war. The Soviets used scalar weapons against the Afghanistans during their war. One may wonder if this explains current American helicopter crashes in Afghanistan and Iraq.
    Scalar waves can be used for impenetrable communication inside an ordinary carrier wave. Artificial potentials can be used for 2 way communication with submarines, aircraft and ships. Scalar waves can be used to tap into normal communications even when encrypted. They can even destroy the enemies equipment if they wish using lock-in mode to locate the source or just continue eavesdropping. radar invisibility can be done by putting multiple transmitters around something to make a spherical interference shell in the bandwidth of the searching radar. Nothing in the air is safe with scalar weapons or anything on the ground, because any building can be penetrated and the inside contents destroyed from either narrow or wide crossed beams. There is nowhere to hide. Scalar beams can be sent by aircraft or satellite or even from the government UFOs of Russia, Britain, Australia and America. They can be sent from the UFOs the Nazis developed secretly in Germany during WW2, and which were relocated to their underground bases in Antarctica and all over South America before the war ended.
    To totally destroy a person's nervous system and kill them instantaneously, a scalar weapon can be set on 'high intensity pulse mode'. This will destroy every living cell, bacteria and all germs so the body falls down like a limp rag, not even decaying in even 30-45 days. There is no living aspect left to decay. Entire groups of people can be killed this way even in a 50 mile radius on peak power. Scalar beams set on a lower power can render a person unconscious to be revived at a later date for interrogation. Crossed scalar beams can cover a whole range of targets from something right through the other side of the earth, to anything under the sea or ground. Not even metal will suffice to protect, as a metal softening mode can be deployed. Scalar beams can be put into X ray mode where a screen can show what is inside something, even under the sea and earth or inside buildings. This is called a remote viewing radar.
    Anything in the sky can be instantly destroyed even from one country to another. All one country needs to destroy anything skybound in an enemy's country is to put 2 or more scalar transmitters forming a scalar wave-form interference grid whereby a shield is locked over a country in high intensity mode and this will cause anything which enters it to be destroyed. This can also destroy anything in the sea and detonate mines. The explosion shows up on the screen as a blossoming of the moving light on the square. The Russians mainly use their interference grids over the USA to control the weather moving hot or cold air where they can meet and create storms, hurricanes, torrential rain or droughts as they please. Earthquakes can be created along with volcanoes erupting according to Tom Bearden. Moisture can be brought from the ocean and sent overland and cold air from the north sent south. Violent thunderstorms can be created. He also claims since 1989 the Japanese Yazuka and Aum sects lease scalar interferometers from the Russians to do weather engineering over the USA.
    However America can fight back with their own scalar weapons. One can silently down passenger planes as need be by sending low frequency scalar beam to make the engine fail, either from the interference grid squares or from even portable shoulder scalar weapon bazookas which can be targeted at helicopters or any aircraft above. Surface naval vessels can be attacked through their hulls as well as ocean bottom mines detonated. Any aircraft, or land vessels including tanks can be fitted with portable scalar weapons. Though tanks can easily be destroyed with them.
    Tom Bearden claims that the Soviets and Americans have been silently downing each other's aircraft since the 1980s. Soviet made scalar weapons downed American aircraft in Vietnam. Right from when USA put up their first satellites the Russians have been shooting them down in cloaked Russian made UFO's with scalar and particle beam weapons. Between 1977 and 1982 Russia shot down many US satellites. At that time they wanted complete control over the skies and had put up killer satellites complete with beam weapons to target US satellites and even the space shuttles. It has been claimed by Tom Bearden that all the early space shuttles were shot down by the Russians and duplicate shuttles were landed from another base. There was a mad rush by the US govt to develop beam weapons to defend themselves against the Russians and they did this eventually shooting down a couple of the Russian made UFOs containing beam weapons. Revenge silently followed by passenger planes of each other's countries being targeted.
    In the early 1970's Hundreds of inmates at the Gunniston Facility of the Utah State Prison were subjected to scalar wave mind control. Inmates tried unsuccessfully to fight back in court. The University of Utah researched at that time how scalar waves could induce the mind into hearing voices, overriding and implanting thoughts into the mind, as well as reading the thoughts. They also developed eye implants. In 1998 scalar waves were used to test subliminal voices in the head in 2 Utah prisons. In Draper Prison, Utah a man called David Fratus in 1988 claimed voices in his inner ears were induced in him as clear as if listening to a set of stereo headphones. The mind control victims of US govt implants are also subjected to artificial voices in the head which are sent on scalar beam by satellite and and the HAARP transmitters and relayed to the GWEN Towers placed approximately every 200 miles across USA. Many of the messages relayed into these American mind control victims are said to come from aliens, with a 'message for mankind'. These 'alien messages' were first given to the prisoners in Utah and they all got the same messages.
    The Russians, having a head start on decoding the brain can send subliminal messages by satellite over whole countries in their own languages, in scalar waves so subtle that the victims think they are their own thoughts occurring. They could make people think "God" is speaking to them and can also give a people suicidal thoughts. There is a suicide wavelength. The Russians and Israelis have been said to do this on mind control data websites. As well, the Americans have been using these subliminals to give 'voices in the head' messages (which includes to those with CIA or military controlled implants) that are supposedly from 'aliens' or "The Holy Spirit" to say e.g. the Second Coming will be here soon or earth needs to be evacuated and the person has been 'chosen'. Only certain people can pick this up according to whether they have implants (which relay messages into the head) or if they are natural telepathics. The mineral selenium when ingested beyond normal levels is said to increase the capacity to hear voices in the head. Though certain races have a higher hearing threshold and are able to pick up synthetic telepathy sent through the atmosphere more than others.
    Russia's scalar transmitters are called "Woodpeckers" because of the woodpecker type tapping transmissions detected from them on the radio band. They have the technology to send subliminals right into a person's subconscious, bypassing the brain and could drastically influence the thoughts, vision, physical functioning, emotions and conscious state of a person by sending in subliminal signals even from a great distance. In the late 1960s the Soviets broke the genetic code of the human brain. It had 44 digits or less and employed 22 frequency bands across nearly the whole EM spectrum. But only 11 of the frequency bands were independent. The Soviets found they could make a person do something just by sending subliminals into the body, bypassing the ears.
    Up to 16 of the Russian Woodpecker scalar transmitters have been observed to carry a common phase-locked 10 Hz modulation. 10 Hz is used to put people into a hypnotic state. The Russians can manipulate the moods of everyone in a 75 mile radius, with a circularly polarized antenna, and people's bodies have been shown to pick up the "new" mode of expression. Even "sleep" frequency will make everyone tired and fall asleep.
    According to the book Project L.U.C.I.D by Texe Marrs, John St Clair Akwei claims that the US National Security Agency (NSA) has had the most advanced computers in the world since the 1960's. The Signals Intelligence (SIGINT) mission of the NSA uses scalar waves for blanket coverage of the USA and can wirelessly tap into any computer in the USA and read the contents. As well as track people by the electrical currents in their bodies, which emanates a particular 'signature frequency'. This is possible because everything in the environment gives off scalar waves at right angle rotations off the normal electromagnetic wave. These can be searched for and tracked and are not subject to constraints of time and space. A person's frequency can be stored on a supercomputer and this can be tracked anywhere. They can be sent subliminal words sent in scalar waves which are so subtle that the person will think they are their own thoughts. Also NSA uses a secret program (developed since the MKULTRA mind control program of the 1950s) what is called "Radiation Intelligence". Scientific research from this is withheld from the public and there are international intelligence agreements to keep this technology secret. Using this technology the NSA records and decodes individual brain maps of hundreds of thousands of people for national security purposes. It is also used secretly by the military for a brain-to-computer link. Activity in the speech center of the brain can be translated into the subject's verbal thoughts and can also show up activity from their visual cortex on a video monitor. NSA operatives can see what the subject is seeing. Visual memory can also be seen and the NSA can place images directly into the visual cortex, bypassing the eyes and the optic nerves.
    When a target sleeps secretly images can be installed into the brain during REM sleep for brain-programming purposes. Speech, 3D sound, and subliminal audio can also be sent to the auditory cortex of the brain, bypassing the ears. This "Remote Neural Monitoring" (RNM) can completely alter a subjects perceptions, moods and motor control. Different brainwave frequencies are connected with various parts of the body and when the right frequency to activate a section of the body is sent a person is powerless to stop it. Pain can be induced in mind control victims this way by targeting a section of the body. This has been spoken of by many mind control victims, accompanied by 'voices in the head' by the operators cruelly asking if it hurt and all done remotely without any physical contact with the victim. There has been a SIGINT wireless scalar wave brain monitoring network in the US since the 1940s according to John St Clair Akwei. He tells us how it is done with digitally decoding the evoked 'potentials' (see first section for more on potentials) in the 30-50Hz, 5 milliwatt electromagnetic emissions from the brain. In these emissions spikes and patterns show as evoked potentials. "Every thought, reaction, motor command, auditory event and visual image in the brain has a corresponding "evoked potential" or set of "evoked potentials". These can be decoded into the current thoughts, images and sounds going on in a target's brain. When complexly coded signals are sent to a victim, bypassing the eyes, optic nerves and ears, the faint images appear as floating 2D screens in the brain. Auditory hallucinations can be induced, creating paranoid schizophrenia.
    The frequency the brain areas respond to are from 3 Hz to 50 Hz. For each brain area these are used: Brain Area: Bioelectric Resonance Frequency: Information Induced Through Modulation. Motor control cortex: 10 Hz: Motor impulse coordination Auditory cortex: 15 Hz: Sound which bypasses the ears Visual cortex: 25 Hz: Images in the brain, bypassing the eyes Somasensory: 9 Hz: Phantom touch sense Thought center: 20Hz: Imposed subconscious thoughts Only the NSA modulates this signal band into evoked potentials or scalar carriers. There are about 100 people working 24 hrs a day for the NSA at Ft Meade on this "Remote Neural Monitoring" (RNM). John St Clair Akwei, after being harassed by this NSA technology brought a lawsuit against the NSA. During the lawsuit process he was harassed by 3D sound, and his associates were also harassed to keep him isolated. No action was taken against the NSA in the 1991 lawsuit. In 1967 an "internationally renowned scientist" and Christopher Hills, a pendulum expert, communicated with some ETs. (It is not known who the scientist was but at one time both Hills and Puharich were working with the medium Eileen Garrett and Puharich was communicating with ETs called The Nine.The same ETs that the Bilderberger group (comprised of world leaders and European royals) who control the affairs of the planet) This is what the ETs told Christopher Hills via pendulum:
    In short, ETs communicated with us via modulated radio-waves, between 10,000 and 20,000 cycles below the known electromagnetic-spectrum. In the carrier-wave by amplitude modulation, mixed with frequency modulation. Single band energy, transmission power less than 25 watts. A naturally present wave on earth the brain modulated - a wave that resonates between the earth and the ionosphere. All humans influence the ionosphere in this manner. A reflecting technique involved. The brain modulation consisted of pulses, akin to those known from neuro pulses. Two humans can use this. Related to something akin to low frequency radar and to ultrasonic techniques but qualified. A mixed electro-acoustic wave function. The electromagnetic-wave induced an ultrasonic transduction in human tissue. The brain radiation has a sonic component to it as well as an electromagnetic component. Electromagnetic-radiation has a sonic component and it's dependent on the medium through which it travels. The scientist cut through months of work. Now HAARP is slicing up the ionosphere, the world-brain, like a microwave knife, producing long tear incisions destroying the membrane which holds the reservoir of data accumulated by all earth's history. HAARP has already punched 360 x 30 miles holes in the ionosphere.
    Tom Bearden also writes that a more advanced form of scalar weapon is known as a 'quantum potential' weapon has been developed by US, Russia, China, Israel and possibly Brazil . These weapons mimic the signature or frequency of a disease by recreating them on scalar carriers. Also any disease can be imprinted onto our cellular system using frequencies ranging from ultraviolet to infrared. Whole populations can have new diseases and death induced as well as latent diseases being activated with quantum potential diseases in targeted areas. Manufactured symptoms of radiation poisoning, chemical poisoning, bacterial infection and even the effects of many kinds of drugs including hallucinogenic ones can be induced with these very subtle scalar waves which flow in hyperspace or the sea of ether. They become imbedded right into the immune system or etheric counterpart of the physical body.
    On the FreedomDomain.Com site a man called Kaznacheyev found that the induction of diseases could be effected by the Woodpecker scalar transmitters in the near ultraviolet range. Experiments at the University of Marburg in West Germany duplicated these disease inducing scalar wave experiments in infrared. Dr Popp of West Germany, after analyzing the virtual photon master control system of the cells found that scalar virtual particle flux which determines the genetic blueprint pattern of the cells can be easily entered with scalar techniques to induce disease and cell disorder at will.
    10 . TESLA'S SCALAR WAVE TECHNOLOGY WAS SECRETLY CONTINUED BY RUSSIA AND THE NAZIS
    While the American government rejected Tesla's energy without wires and left him penniless, Russia and Germany asked Tesla to work for them. He turned them down, but according to Preston Nichols he faked his death in 1943 and was spirited away to the UK. From then on it was a frenzied battle between the Soviets and Germany to develop scalar technology. Russia got a head start in learning how scalar waves can be drawn from hyperspace by sending an agent to seek out a man in Utah who built a machine for doing this Utah. A Soviet agent destroyed the device after learning how the machine operated.
    The man, T H Moray learned about Tesla's 'sea of ether' and had made a scalar interferometer. Germany had developed anti-gravity technology in 1939 by back-engineering a crashed UFO. By WW2, they led the world in radar and infrared science as well as radar absorbing materials and radar cross section. Some leading western experts think they developed radar cross section beyond western levels today, but there is evidence of an alien alliance during the war so this may have been influential. The Germans were using time reversed waves, which caused a scalar wave to follow back and respond to the source of a received ordinary electromagnetic wave. During WW2 many of the best Nazi scientists escaped to a base they'd developed secretly in Antarctica, getting supplies from South Africa as well as to German communities in Argentina, Chile, Paraguay, Peru, Uruguay, and other Latin America countries. After the war Americans moved the remainder of the best Nazi scientists to US, with the Soviets, French and British taking the remainder to their countries. However the Soviets became angry at the Americans for taking first choice of Nazi scientific brains, so in 1946 they just cleaned out the majority of scientists and technicians back to the Soviet Union, about 275,000 men plus all their families from Soviet occupied eastern Germany. By the 1950 the Soviets had developed time-reversed waves. They has also forced the captured Germans to build them a fleet of anti-grav saucers complete with particle beam and scalar beam weapons. In Antarctica the Nazis had Tesla's "Death Ray", capable of sending a lethal beam even to the moon to create an incandescent spot, when aimed at it. Tesla devastated with his "Death Ray" - likened to a modern day particle beam weapon. According to Al Bielek the Russians have particle beam weapons which can shoot 1000 miles into space, and they use these to shoot down any UFO within 200 miles radius of their sky. The Americans also have many particle beam weapons and they too shoot down UFOs. There is apparently a war going on in space, and the Russians and Americans have secretly got together to fight it. It is unknown who the UFO occupants are, but the Nazi's in Antarctica are said to be invincible with their superweapons.
    Japan now has scalar weapons and has got together with Russia to develop them. In 1991, according to Harry Mason, Russian President Gorbechev offered to lease the Japanese the super-secret intercontinental scalar weapons, capable of producing earthquakes for $900 million, which they'd used in the Soviet Union since the 1960's. Tom Bearden also claims they leased them in 1989. A Joint Russian-Japanese university was set up to develop new weapons with Japanese microchips to overpower the US and jointly rule the world. After Tesla "died" in 1943, his papers were sent to a Tesla Museum in Yugoslavia, where the Japanese obtained the knowledge of Tesla technology. The scalar weapons were developed by a Japanese scientist an IQ higher than Einstein.They too, like the Americans tested their scalar weapons in the outback of Western Australia, possibly using a base in Antarctica in which to send scalar waves to their Australian transmitter to produce earthquakes and Tesla globes. The Japanese scalar scientists are tied up with various cults and feel that the Japanese emperor should rule the planet, as well as having a policy of exacting revenge on former enemies culminating in a "Final War" against the Christian west and Islamic world. It is the Japanese Aum sect and Yakuza mafia who are still leasing the Russian scalar transmitters and have steadily used them for weather engineering over America since the nineties for target practice. Bearden claims that the Japanese may be allowed by the Russians to down planes now and then. The Japanese cult members in their govt are also tied up with North Korean cult members. The Russians have been weather engineering over America since the 1960's using their interference grid to target specific areas.
    Unlike Western universities, Eastern Europe and Russia have always included Tesla's scalar wave research openly in their curriculum and so they got a head start with multiple facilities built all over the Soviet Union to build scalar weapon transmitters starting from the 1950's. This was further hastened by making captured East German scientists work for the Soviets leading that country straight into the space age, giving them UFOs fitted with scalar and particle beam weapons. The UFOs even had cloaking technology. America, even though they had Nazi scientists working for them after the war at Area 51 on anti-gravity, didn't realize how advanced the Soviets had become with scalar technology until they found out they'd been secretly attacked during the 1950's undetected. In 1960 the Soviet premier Kruschev announced to the world, that they had "superweapons". In 1963 they deliberately destroyed a US atomic submarine undersea by Puerto Rico with scalar weapons. They next day over the Puerto Rico Trench the Soviets used scalar weapons in a different mode to produce a giant underwater explosion. US was defenseless against an unknown type of weapon. In 1965 the Great Sandy Desert in Western Australia was mapped out and chosen by the US govt to begin scalar weapons testing. Even though 'officially' Tesla's papers were kept by the FBI after he died and were labeled 'top secret', lest they get into the hands of the enemy, Tesla had passed all his knowledge and research onto a young American physicist 2 weeks before he died in 1943. The US military in Western Australia tested crossed scalar beams aimed into the ground to create earthquakes on a target map of squares and also created Tesla globes from crossed scalar beams in the sky. Pine Gap the secret underground American military base has 2 scalar transmitters and they also have at least another in Exmouth, N Western Australia. Other American scalar transmitters besides various ones all over USA are at Alaska, Puerto Rico, Greenland, Norway and Antarctica.
    Though many countries have scalar weapons now, other countries could easily be a target of those with scalar weapons and never know what was the cause of their explosions, mind control or weather engineering. So of course more and more countries are getting the scalar technology needing it to defend themselves as well and this keeps getting passed on especially by the Russians. The other thing is one may know it is a scalar attack but have no idea who did it. The known countries which have scalar weapons are: America, Russia, France, Australia, Germany, Japan, China, Taiwan, South Africa, Israel, Brazil, UK and Argentina as well as various populations of Nazis still operating in Antarctica and all over South America. It is unknown how Brazilians got scalar weapons and quantum potential weapons, but the Brazilians have had alien technology for some time and also the Vatican has covert technology and has been said to have a base for this in Sth America for their secret space program. There is extensive coverage of Brazil's space program in my 40 page article "Scalar Weapons: Read it and Weep" in Vol 3 of the 'Universal Seduction' book series. This covers China and Japan's weapons as well as extensive coverage of Russia's attacks on America, especially the space shuttles and the technology of the Nazis in Antarctica. Others may have them such as Ukraine and Nth Korea but as yet no proof exists for these countries. Even in the alternative press not enough has been said about scalar weapons to the extent where normal conspiracy researchers and writers are as familiar with their dangers as they should be because even online they hardly get a mention on conspiracy sites. Yet they are probably the most life threatening thing on the planet.
    Syntax Error : Integer Out Of Range
    Hooray For Tits & Fannies
    DK Veteran cablefreejunkie's Avatar
    Jul 2008
    on a sheet of lino
    tesla was a genius thats for sure,but im sure he would not of wanted these weapons designed from his genius inventions etc
    The control of information is the consolidation of power
    ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
    IF I HELPED HIT THE THANKS BUTTON
    Dufner
    Johnner's Avatar
    Jun 2010
    Éire
    Yes,yes,yes !!!!!
    I knew that by watching every single episode of Stargate-SG1,that it would come in handy some day !!!!
    HTC. The place to be,with Crapatalky !
    Shite Link King Shady's Avatar
    Dec 2010
    192.168.1.xxx
    Quote Originally Posted by cablefreejunkie View Post
    tesla invented a death ray... tunguska was caused by it... allegedly.. dont think he cared much about wether he was creating weapons or lightbulbs
    Jul 2008
    on a sheet of lino
    Quote Originally Posted by Shady View Post
    allegedly being the word to note here
    theres no solid evidence that it was caused by anything tesla had invented,just pure speculation
    cunny's Avatar
    Jan 2009
    The Shoutbox
    I think red should ease off playing command and conquer for a few years
    nara's Avatar
    May 2008
    Home
    13. THEY DON'T EXIST.
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    ~~~~ me thats some copy n paste red, thought i was bad, that post just about equals all my copy n paste shite in one post , i was going to read it but aint got 3 months spare
    Nov 2011
    Quote Originally Posted by nara View Post
