Hayssam1 (20th September, 2021), jackaroo ted (16th November, 2018)
With this link you open your immo dump, and the pin is at the address marked in red.
https://hexed.it/
Yeah, I was hoping there was another way of obtaining the PIN digitally, without requiring chip readers.
So the T300 didn't read the PIN from the ICU in the Isuzu Trooper?
My Chinese clone Autokey MVP couldn't read it...
Nobody on this planet is completely self-sufficient....unless they are delusional.
We are born into dependency, live dependently, and die the same way.
If we have a Government Issued Birth Certificate, Tax File Number, or Passport, then we are a commodity of the Government.
If we have a loan of any kind, then the lender owns the borrower until the debt is repaid.
BTW, I appreciate all your helpful advice in solving my PIN problem......
So you didn't buy the T300 to see if it would read the PIN?
Or you did buy the T300 and it wouldn't read the PIN?
Have you seen the NewRockies Passkey 3 bypass chip?
Apparently it doesn't require a PIN, it intercepts the ECU - ICU communication, and gives the ECU a false verification.
Once verified, all functions of the ECU are fully operational - Starter Motor engages, Injectors Enabled, and Crank Sensor enabled.
Apparently this works even if the original ICU is completely dead (even if it wont power on)....
I've read that you can replace the ICU, do a 30 min reset (GM - Passkey 3 reset) of ICU and the PIN is copied from ECU into the new ICU?
Obviously the PIN is also stored in the ECU, so I was hoping there was a way to extract the PIN from the ECU, even in the case of a dead ICU.
Well I received my T300 today from aliexpress and it WILL NOT read the Immobilizer PIN from an Isuzu Trooper (1998-2004) with 4JX1 4 cylinder Turbo Diesel Engine!
The vehicle is listed, and it will allow me to read stored Error codes, program keys, clear keys etc....but will not allow you to read the PIN. So you MUST know your PIN otherwise this key programmer is useless.
A topic that interests me
