Results 1 to 7 of 7
Thread: epg
    Feb 2009
    Default epg
    is there a epg for the dm800se i downloded cooltvguide from tspanel the reset the box the pressed set crossepg and then download it flASHES for about 3 sec then finishes then i exit then press tv but no epg please help ?
    Dec 2012
    how to upgrade sat list in skybox f3?
    Jan 2013
    Update providers In CrossEPG Setup, upgrade your area providers and start download
    make sure that you tick one of the providers first before you update.
    Liverpool
    If you're in UK, set it up for 28.2e, either using bbci or rytec options.
    set up cooltv guide to start with bouquetlist and then choose guide format, and configure multiquickbutton to map one of colour keys to cooltvguide. You can then press colour button you mapped, and are presented with a list of bouquets to choose, very similar to sky setup.
    digicon's Avatar
    You dont need Multiquick button to map Cool Guide to one of the coloured keys as its already built into the Cool Guide setup
    May 2013
    ok lets get a full epg for ya mate first you will need a memory stick or hdd (memory stick is better in my opinion)
    insert it to back of box
    press menu
    setup
    cross epg
    configure
    storage device should be your memory stick
    make sure all other settings in this page are selected to yes
    exit this page
    goto open tv providers
    select sky uk opentv (astra2 on 28.2)
    press green then yellow to install
    now you should have a full 7 day epg for all channels
    hope it helps mate
  8. The Following User Says Thank You to willbert For This Useful Post:
    fat don (30th November, 2013)
