Results 1 to 12 of 12
    Jul 2012
    Bel air MD
    Default australin incals isx
    Hi lookin for australin incals for isx thanks in advance.
    Oct 2012
    Norcal
    Quote Originally Posted by Gear head View Post
    Dunno what you mean, to my knowledge all the calibrations cummins has are worldwide. It depends on the ecm part number whether you have the option of an australian calibration. If you go under certificate codes on your calibrations in insite it will list the option to display all certification codes. I.e. china, mexico, aus. One of my ecms (cm870) I have only lists carb and epa cal, as that is all that is available for that ecm. But also have a cm871 (part #3689275), that lists mexico and australian calibration.
    Aug 2012
    post the cpl number i can download it for u pm
    Aug 2012
    cm 2250 ecm 4993120 thanks, cummins isx.
    Oct 2012
    Norcal
    Quote Originally Posted by jdawg View Post
    There are no australian certification codes for that ecm in the Oct. 2012 incal files. The only files that are available are for carb, epa. I know your frustration as I tried the same thing.
    Jul 2012
    Bel air MD
    There are cummins engines in 2012 trucks in aust. That have no dpf but have egr. I know they will work i just need the right one. Ive been told by a good source it works.
    Jul 2012
    Bel air MD
    You should be able to switch the cm number as long as ecm part number is the same.
    Oct 2012
    Norcal
    I'm curious gearhead, as to what you mean by changing the cm number. Not trying to be a jerk, but I'm still researching this. I know it works, but the ones i've seen done are the ecm serial numbers that have the available australian calibrations. It is possible with calterm but not insite, as insite won't allow you to calibrate across ecm serial codes. It will allow you to cross cpl but not serial. As far as calterm calibration files that I don't know. But I would say it is entirely possible with calterm, if you can find the configuration file and the calibration you are looking for. From what I've seen australian trucks use different ecm serial codes than what they put on the trucks here in the states.
    Junior Member detroit747's Avatar
    Feb 2012
    Yeah your right we are a fair way behind on the whole pollution control thing here in Australia.. Let me know if I can help ive got access to a few new ones
    australia
    got a mate here bought a peter build from the state with the new sig com rail engine with the ad blue on it are there any new cal out there over 620 for this engine
    Jul 2012
    Bel air MD
    Quote Originally Posted by detroit747 View Post
    Can you send some isx incals from over there might be able to use thanks alot.
    Nov 2017
    tn but originally from ny
    id be interested in these files too, cm871 and cm2250
