Hello.
Here is solution for you (in archive two dumps for 1.4 cars with MT and AT):
Hello.
can you get me pass plz
zohar thanks a lot but car still dont work, have you another file?
Very strange, my be, problem not in immo. try to check crankshaft sensor signal...
I have tested this dumps many times - works on 100%
(also works on Acccent 1.5, Elantra 1.6AT).
No need to cut any wires, just program flash 29f400
This is OBD flasher for Kefico ECU of Kia/Hyundai (ECU inside seems like Bosch M7.9.7 on MCU C167 with ext. flash 29F400and ext. eep 95xxx). Writing of flash is possible on car via OBD, no need to dismount ECU (reading only in boot mode via K-line or via flash desoldering in programmer). Works fine with K-line FTDI adapter.
BR
geeroam (2nd June, 2016)
hello zohar
thanks you
hello sir
cam you please send me the pass for the 2 files via PM. thanks in advance
Hi.
I hope this picture will helps
And similar flasher for KIA ECU Kefico (ECU in alluminium case) in attachment.
BR
can you send me pass please for files with immo off
hi zoher could u send pass plz?
