Results 1 to 2 of 2
    Dec 2012
    Default CCcam problem on DB 7025+
    I bought a used DB 7025+ and flashed an image and the plugin CCcam. Now I can edit the CCcam.cfg file by adding the C line but it seems not to be working. Does anyone has experience with this.
    Please let me know and I can give yo aditional info if needed.
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Telnet to the box
    Check if it is running with
    ps x | grep CC
    If it is then kill it with
    killall CC<tab>
    run it again with
    CC<tab> -d
    That will give messages in the command window. If you read hte messages it will tell you what is going on, probably a syntax error in CCcam.conf
